electrical problem
  • Thread starter Thread starter swigs84
  • Start date Start date Dec 16, 2004
swigs84
Vegas
Dec 16, 2004
  • Dec 16, 2004
ok i just got done doing a 5 lug conversion on my 91 GT and i went to take it out tonight and i have no brake lights at all......doesnt have anything to do with what i did to it but........when i close the doors or the hatch all of my lights flicker off and on twice......the fuse for the brake lights is the same one for the hazards and my hazard lights work......i dont think there is a relay or anything anywhere for them is there?
G
GreenGTVert
  • Dec 16, 2004
Check your ground straps, then check for loose wires coming from the connectors. Good luck, me and electricity don't get along very well.
HISSIN50
34
129
Dec 16, 2004
  • Dec 16, 2004
if what Green GT said does not work (i agree with what he said), and brake lights are the only thing AWOL, check the switch on the brake pedal to see if something got knocked off or whatever. should have 12 volts to it, and when the pedal is pressed, 12 volts out. then check the wiring at the sockets (test light) and check the grounds in the back with a DMM (as said). good luck.
swigs84
Vegas
Dec 17, 2004
  • Dec 17, 2004
with the pedal pushed in i have no power at the sockets......i know there is a ground right back there by the lights are there any more for the lights i need to check
HISSIN50
34
129
Dec 17, 2004
  • Dec 17, 2004
how did you test for power at the socket? if using a test light, your light would be supplying the ground (to illuminate the test light). that suggests you have no power going back there.
go back to what i said above about the brake light switch on the brake pedal. if it is open when the pedal is pushed, no power will be sent to the stop lights.
good luck.
T
Need help 67 hazard flashers not working
  • THS70
  • Jan 21, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jan 29, 2026
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
Resolved Wiring electric fan
  • cbac89
  • Aug 29, 2026
cbac89
Brakes FOX BRAKES ISSUES
  • PonyGTrider
  • Jan 11, 2026
  • 2 3
3K
Fox 5.0 Mustang Tech Jan 31, 2026
Mustang5L5
Z
Turn signals not working at all, but hazards do. 91 fox LX 5.0
  • Zeke1995
  • Jun 22, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 12, 2025
Jarhead67
J
