Electrical problem...
  • Thread starter Thread starter 66 Tiger
  • Start date Start date Sep 7, 2005
66 Tiger
249
Virginia
Sep 7, 2005
  • Sep 7, 2005
I have 8ga wire with a 40 amp maxi fuse installed between my alternator & battery. The fuse blew this morning ( without me knowing ) , & I pretty much killed the battery driving it to work.
After work I replaced the fuse & thought everything was fine. About five miles down the road the car started missing real bad so I figured the fuse blew again.
( I was right )
My question is - if the battery is not fully charged could that be the culprit with the fuse's? I went through four fuses this afternoon before finally calling it quits. Everytime I reved the motor the fuse would pop. I'm guessing there's to much load with the dead battery. Anyone have any ideas. Thanks...
T
TheUser
1,859
Springfield, MO
Sep 7, 2005
  • Sep 7, 2005
I assume you mean 140amp fuse?
With a 3g, I would think you'd want at least 4ga wire.
Although I don't know for sure, you idea w/ the battery might be correct. I'd pull a battery from a friends car and see if the same thing happens. Do you know what caused the battery to go low to begin with?
HISSIN50
34
129
Sep 7, 2005
  • Sep 7, 2005
The state of charge should not have much to do at all with the alt fuse (we do need to clarify the wiring stuff - 8 gauge is what the stock wiring tapers down to IIRC).
One can jump a dead battery and run off the alt alone and not blow the fuse. Remember these are slow-burn fuses. The alternator has tiny spikes, but the slow-burn nature of the fuse keeps them from blowing every time a spike pops up. But a 40 amp fuse sure could burn.
I would look for a loose connection on the power cables from the alt to the battery or solenoid. Esp if you kept the stock wiring hooked up (with a 40 amp fuse) and ran a new cable (ran both in parallel). The new cable might have a poor connection or too much resistance, and the power is taking the lesser path of resistance - the smaller wire.
Good luck.
66 Tiger
249
Virginia
Sep 7, 2005
  • Sep 7, 2005
I left the original alternator wires ( x2 yel 10ga ) hooked up to the new alternator. I then installed a separate 8ga. I kind of figured that would keep me from having to run a single 4ga.
The 40 amp fuse has always been sufficient. Occasionally it has blown - but I figured it had to do with starting the car when ALL the accessories were on... So maybe I should " up " the amperage of the fuse?
66 Tiger
249
Virginia
Sep 7, 2005
  • Sep 7, 2005
Good luck.
You mentioned a 40 amp fuse could burn... What amp fuse would you recommend?
Far as the connections go - I replaced the alternator today too ( lifetime warranty at Discount Auto ), so I'm sure all the connections are clean & tight. I thought I would cover all the bases so I even replaced the ignition cylinder.
You also mentioned the factory wiring going to the IIRC. What & where exactly is that? Also - does the factory wiring have a fuse in line as well?
Thanks...
HISSIN50
34
129
Sep 7, 2005
  • Sep 7, 2005
Thanks...
The stock 10 AWG cables taper down to an 8 AWG cable IIRC (If I Recall Correctly). It does have a fusible link on it and is good for ~ 50-55 amps continuous feed, IMHO.
The issue IMHO is all the cables you have run. I would go get a 4 AWG battery cable and an inline fuse and holder (125 amp fuse should work) and ditch all those little wires you have now. I still think you have a bad connection (resistive at a minimum) and so the power is being diverted through the wire with the 40 amp fuse.
For around 20 bucks or less you can redo it and have it be right. I would remove the new cable you added - toss it. Then leave the two stock alternator wires on the solenoid - just disconnect and protect them at the alternator side. Remember - those are still 'hot' cables.
Good luck.
Electrical Parasitic Draw, Fuse 8
  • N8827N
  • Sep 15, 2026
Fox 5.0 Mustang Tech Sep 18, 2026
AeroCoupe
T
Inside is completely dead
  • TunaCar
  • Oct 18, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DadLife0724
F
Alternator Not Charging
  • Fri Guy
  • Aug 29, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 31, 2025
AeroCoupe
A
Resolved Electrical Help Please
  • Alabama
  • Jan 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 22, 2026
AeroCoupe
Electrical Complete Electrical Power Loss
  • stevetheheathen
  • Nov 14, 2024
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Nov 20, 2024
stevetheheathen
