  • 1994 - 1995 Specific Tech
electrical problem
  • Thread starter Thread starter nickgt5.0
  • Start date Start date Jul 25, 2008
nickgt5.0
96
Snohomish
Jul 25, 2008
  • Jul 25, 2008
one day my radio, speedo, odometer and mileage clock, power mirrors, all stopped working. the fuse in position 8 was blown and now fouls any fuse you put in. any ideas?
Bosko5.0
1,067
longwood, FL
Jul 26, 2008
  • Jul 26, 2008
Make sure that there are NO bare wires under the dash rubbing any metal. check the clutch pedal and brake pedal wires are known to rub against them and blow fuses.
HISSIN50
34
129
Jul 26, 2008
  • Jul 26, 2008
The fuse 8 feed to the cluster is lt green/yellow. Pull the cluster and see if it's chafed any place.
Otherwise you will have to disconnect each item on the circuit and replace the fuse. Then plug each item in till the fuse blows.
D
Speedo and tach dead
  • Davinrobinson1
  • Jul 19, 2026
1994 - 1995 Specific Tech Jul 26, 2026
fasterthangas
F
Electrical Parasitic Draw, Fuse 8
  • N8827N
  • Sep 15, 2026
Fox 5.0 Mustang Tech Sep 18, 2026
AeroCoupe
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
Electrical V8 swap no power to anything
  • Bullittsmith
  • Sep 12, 2026
1994 - 1995 Specific Tech Sep 15, 2026
Mcmahst
T
Inside is completely dead
  • TunaCar
  • Oct 18, 2026
SN95 4.6L Mustang Tech Oct 20, 2026
DadLife0724
