Electrical Problems/ headlights stopped working
  • Thread starter Thread starter fanopj1
  • Start date Start date Jun 28, 2008
fanopj1
17
Palm Coast, Florida
Jun 28, 2008
  • Jun 28, 2008
The other day my headlights would not come on. I have checked the bulbs, replaced with new, still not working. Switched out the headlight switch from my DD coupe, still not working. Traced wires from headlights to dash, and found nothing. The parking lights still work, as well as the tailights. I checked and rechecked the fuses, all OK. I do not know if these are on the same circuit or fuse, but my dome light stopped working as well. Everything else if good. Just a little puzzled. Any suggestions or advise where to look next? Thanks
Andrew
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jun 28, 2008
  • Jun 28, 2008
No info about your car's model year, EFI or carb, no mods listed. Makes it hard to troubleshoot when we don't know what you have.
Therefore, no clue as to which wiring diagram you need. The wiring changed several times between 79 & 95.
That's why it is a good idea to use the sig under the user control panel (User CP) option. It allows you to post your car year & mods, which help greatly when troubleshooting things. No, it is not there for us to snoop and see any "Secrets" you have hidden away under the hood. Be a good stangnetter and update you sig for future reference & don't keep us guessing.
fanopj1
17
Palm Coast, Florida
Jun 28, 2008
  • Jun 28, 2008
Sorry, my mistake. I will update. It is a 1993 hatch w/ 302 explorer upper/lower intake, C&L 76 mm mass air w/ inlet tube, shorties with x-pipe and flows, 3.73's 5 lug conversion.
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jun 28, 2008
  • Jun 28, 2008
The headlights used the turn signal/multifuction switch as part of the light circuit. Try the lights and pull back on the turn signal to see if your high beams work. If the high beams are OK, then the turn signal/multifuction switch is suspect. If not, then the on/off switch for the headlights is suspect.
2000xp8
SN Certified Technician
Aug 8, 2003
8,075
1,658
194
NJ
Jun 28, 2008
  • Jun 28, 2008
When i had put those white bulbs in (which are too much draw on the factory wiring).
The heat loosened all the connections in the plug that goes to the light switch.
Visibly nothing looked wrong, but a little yank on the wires from behind the connector and they easily fell out.
fanopj1
17
Palm Coast, Florida
Jun 28, 2008
  • Jun 28, 2008
I tried the high beams but they did not work either.
2000xb8, what do you have to do, replace the plug that goes to the headlight switch? I pulled on the wires and one of them came off. It is th ethick red wire that seperated from the plug itself. I put the wire back on, but still no headlights.
A
aaron1daat
  • Jun 28, 2008
May be the headlight harness
Andrew
I had the same problem with my 89 gt. I had tried everything you have described. It was finally tracked down to the actual headlight harness. There was a couple of burnt wires that completed the circuit between the headlights.
Hope this helps
Aaron
2000xp8
Aug 8, 2003
8,075
1,658
194
NJ
Jun 28, 2008
  • Jun 28, 2008
I went to the junk yard and cut and spliced another connectors on.
You should be able to jump wires out and make the headlights work (if the plug is the problem).
But you have to know the colors, and offhand i do not know theym.
HISSIN50
34
129
Jun 28, 2008
  • Jun 28, 2008
Try to use flash-to-pass [not the high beam setting]. FTP uses a different power source, thus it's a way to differentiate if the issue is fore or aft of the MF switch.
Good luck.
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
A
SN95 Multifunction Madness! Need some big brain assistance from you folks
  • Awnaw
  • Oct 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Tuesday at 5:36 PM
AeroCoupe
Electrical Foxbody Dash & Hazard lights not working
  • sjmcr
  • Jun 30, 2025
Fox 5.0 Mustang Tech Jul 27, 2025
Mindseye007
M
Need help!
  • Masonevans726
  • Dec 17, 2025
1996 - 2004 SN95 Mustang -General/Talk- Dec 17, 2025
Masonevans726
M
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
