Electrical question and code 91,41
  • Thread starter Thread starter JSSuper455
  • Start date Start date Dec 17, 2005
JSSuper455
197
UT
Dec 17, 2005
  • Dec 17, 2005
The electrical question: On the negative battery cable, there is a smaller wire that travels from the post to a bolt on the inner fender (Ground), then into a smaller black/yellow wire (Thats what colors it looks like to me anyway). The smaller wire has, what looks to be, a fusable link then progresses into the wiring harness below/behind the solinoid. I can't really tell where it goes from there. And mine is very melted/eroded (the fuse link, not the wire but battery acid will do that over time). Therefore I'm not sure if its a fuse link or relay or what but it looks very much like a fuseable link (Whats left of one anyway). Now why a fuseable link on a ground wire? and what does it link to? Lastly, I need to replace it so what size of amp does it require?
Its possible my above problem may contribute to the following lean condition in some way, since the connection was not very good.
Secondly: So for the last couple of months I've been noticing random Check Engine lights. They come and go as I'm driving the car. I wasn't driving the car that much during this period of time either, but I decided to put it away and diagnose it later.
Purchased a code reader and a FP guage this weekend. Drove the car to running temp. As I pulled into my driveway I get the Check Engine. I shut the car off and pulled the codes, KOEO. Recieved code 91 and 41. The car is obviously trying to tell me its a little lean. I connected my Fuel pressure guage, and at IDLE its at 38 psi, as I start to rev the engine it drops to 30-32 area. I didn't test WOT, but I revved it as high as say 3,000rpm. My 02 sensors are fairly new, maybe 3 years old at most. I'm not saying they are good, just saying they are fairly new. They could have easily failed, but I thought fuel pressure was supposed to stay at 38psi. I have plans for a larger pump thus a 3G alternator as well. A stonger pump should maintain the higher fuel pressure resulting in more fuel delivered through the injectors no? Also, If I need 24# injectors and calibration tube for the C&L MAF, I don't have a problem with that. Or if that eroded link is for the fuel pump in some way, it wasn't getting a very good ground.
One problem at a time though, first I'll fix that link with a new one. Then test things a bit. Then I'll be getting a bigger pump and 3G anyway just because I feel that with the mods I have its a logical choice.
So anyone know what that negative grounded fuse link is for?
HISSIN50
34
129
Dec 17, 2005
  • Dec 17, 2005
The ground for the computer is attached to the driver side fender with a bolt. About 6" down the puter ground is a connector that looks like an inline glass fuse holder. Is that what you are referencing? James (The User) has posted pics of it before.
Good luck.
JSSuper455
197
UT
Dec 17, 2005
  • Dec 17, 2005
Thats the doohicky I was talking about. Its a good thing to know. I tried searching for every word I could think of except Computer, simply because I didn't know what it went too. So it is a glass fuse holder then?
Well I'm atleast glad to know what it was for, but its probably not associated with my lean burn problem.
JSSuper455
197
UT
Dec 17, 2005
  • Dec 17, 2005
I found it now that I knew what to loook for.
http://forums.stangnet.com/showthread.php?t=596231
But I still can't find what size of fuse it had in it....20 amp is what I'm guessing, but I'm not sure.
Actually jrichker described it as a quick release, so maybe its possible it doesn't even have a fuse in it at all. Wich would make sense to me, since a fuse link on a ground didn't make any sense to me at all. Either way its an easy fix.
  • brandyn200
  • Jun 20, 2026
AeroCoupe
Resolved Wiring electric fan
  • cbac89
  • Aug 29, 2026
cbac89
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
  • dan50
  • Jul 18, 2026
dan50
Electrical V8 swap no power to anything
  • Bullittsmith
  • Sep 12, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Sep 15, 2026
Mcmahst
