Electrical Question
69Rcode_Mach1
1,473
Salt Lake City, Utah
Hi guys i am usually in the classic forums because thats what i own, but for the record I love the foxbodies and want to own one someday. Anyways my friend has a 1990 LX 5.0 and his tachometer doesn't work anymore. How can I get his guage cluster out and take a look at that thing. Any ideas on whats wrong and how i can fix it? Is it hard, hows the wiring on these foxbodies? Thanks in advance.
If the tach has stopped working, it's most likely done for, and there's not anyway I know of to fix it. Might be time to start watching Ebay for a nice used one.
It's easy to remove the cluster, but all the connections are made through a single plug. Just drop the lower dash and the shroud around the steering column. Then unscrew the hood that surrounds the cluster. Of course you'll have to pull out and unplug the switches to either side of the hood. Once that's off it'll be pretty obvious what to do. Oh, you do have to unclip the speedo from behind the dash though. No worries, it's not hard, just tilt it to one side and it will slide off. Just push it on straight to put it back on.
