I would think that is ok. Here is ford's recommendations on how to test for electrolysis.
Determine whether coolant condition is acceptable.
Remove both cables from the battery and ensure they do not contact each other or the vehicle.
Touch negative lead of voltmeter to engine ground and positive lead in the coolant.
NOTE: POSITIVE TEST PROBE IS IN THE COOLANT FOR TESTING.
Check the voltage in the cooling system. If less than or equal to 0.4 volts (V) OK, reconnect battery cables and proceed to Step 2.
If greater than 0.4 V, flush cooling system thoroughly.
Recheck voltage less than or equal to 0.4 V.
Reconnect battery cables.
Refill the system with appropriate Motorcraft® engine coolant.
Check for loose or missing grounds at static conditions.
Turn off all accessories. Turn ignition on but do not start engine.
Test with ground probe to battery ground, engine ground, and vehicle ground sequentially.
Voltage less than or equal to 0.4 V on all grounds OK.
Any one greater than 0.4 V, check and clean ground cable connections.
Check accessories without using the on off switch on the vehicle instrument panel, use a jumper wire to ground.
Plug in engine block heater, if equipped, and test.
Unplug engine block heater, if equipped.
Check for loose, missing, or inadequate grounds.
Crank engine but do not start.
Monitor voltage while cranking. less than or equal to 0.4 V OK
If greater than 0.4 V, ground or repair starter.
Start engine and run at about 2000 rpm.
Turn on all accessories including those customer only uses occasionally such as CB radio, cell phone, etc.
Voltage less than or equal to 0.4 V OK
If greater than 0.4 V, turn off one item at a time until V drops to less than or equal to 0.4 V. Repair ground to the accessory just identified.
Turn the DVOM to AC volts.
Check for ANY AC voltage greater than 0.4.
If any AC voltage is present then try turning off each accessory one at a time including blower motor and any fan motors.
If AC voltage is still present then shut engine off and remove B+ from the alternator and tape it up then retest.
If voltage drop is gradual to less than or equal to 0.4 V, the ground straps may simply be overloaded by added accessories. Test by using heavy gauge jumper to ground. If indicated, install heavier gauge ground strap(s) and recheck.
