eletric fan help
  • Thread starter Thread starter hernandez
  • Start date Start date Jan 17, 2006
hernandez
44
  • Jan 17, 2006
i have 88 mustang gt and it overheats, i have a electric fan that i bought at Auto Zone, and i don't think it is doing its job. i put a new 180 thermostat in about a week ago and still the same stuff, overheating.
HISSIN50
34
129
Jan 17, 2006
  • Jan 17, 2006
How do you know it is overheating? Or is it running hotter than you would like? And is this per the stock gauge?
When does it act up? At speed or in town/stationary?
Good luck.
srothfuss
Last night I stabbed the same guy 7 times in a row
Oct 17, 2004
1,796
Woodward Ave.
Jan 17, 2006
  • Jan 17, 2006
How (when) does it overheat?
1. @ Idle only
2. @ Speed - Highway or stop and go
3. Both of the above
Does your fan have a shroud that covers the entire radiator? In order for the cooling system / fan to be effective it has to pull air across the entire radiator surface. A much larger CFM fan is probably the answer [ebay search MarkVIII fan for a better unit]
Did you use just a switch to flip it on and off? Or are you using one of these: www.dccontrol.com The DC controller is the best unit on the market that I have found in my recent research.
Edit: I was beaten to the questions.... slow typing will be my excuse
95cobraguy
637
11
Concord, NC by way of LI, NY
Jan 17, 2006
  • Jan 17, 2006
convert to a 94-95 electric fan.
hernandez
44
  • Jan 18, 2006
all of the above, both idling and running, do you think that it is the electric fan or something else.
srothfuss
Oct 17, 2004
1,796
Woodward Ave.
Jan 18, 2006
  • Jan 18, 2006
If it's overheating at idle, It might be the fan. Tell us a little about the car before we can really say though
Are you using underdriven pullies?
How is the waterpump?
What Thermostat are you using?
State of the coolant in the system?
HISSIN50
34
129
Jan 19, 2006
  • Jan 19, 2006
If it runs hot at speed, then more than the fan is likely causing it.
Like Steve said, give a run down on all the components and their age (if you can).
Good luck.
CarFreakGT
20+ Year Stangneter
May 26, 2003
395
11
29
Louisville, KY
Jan 19, 2006
  • Jan 19, 2006
Or try to find a Taurus electric fan, if you think that the one you purchased isn't doing the trick. I got one on e-bay. I don't remember exactly how much I paid, but it was around $30. I haven't had a chance to install mine yet because of the holidays, but I did a search and got a lot of good info here on stangnet.
Someone already mentioned that the DC controller is the way to go. That seems to be the consensus of most everyone on here. That's what I'm going to use. Good luck!
hernandez
44
  • Jan 19, 2006
ok here is the run down 10,000 miles on rebuilt motor, ported and polished heads and intake, E-303, underdrive pullies, cold air intake, 1.7 RR, new valve springs, new pushrods and lifters, longtube headers, custome x pipe, slp mufflers dumped, t56 conversion, upper and lower control arms, 3.73, traction bars, chrome 17x9 cobra r rims, 140 alternater, Eletric fan, 160 speedo gauge, HD 3 core radiator, and a 180 thermostat
hernandez
44
#10
  • Jan 19, 2006
  • #10
today i am going to the local junkyard to see what i can find, i heard that the 1999-2006 volvo v70, xc70, s80, s60 electric fan is a inch short of a direct fit, but i will see what i at the junk yard. if nothing then Ebay
srothfuss
Oct 17, 2004
1,796
Woodward Ave.
Jan 19, 2006
#11
  • Jan 19, 2006
  • #11
Alright... now we are talking. From the list of all your stuff, I would assume that your car is indeed in a pretty good state of tune. I am still curious to know if the Autozone fan shroud covers most of the radiator surface or not and what CFM it pulls. But forget about that for the moment...
The other thing that caught my eye was the U/D pullies. Since they turn your accessories slower this might be effecting your water pumps ability to get cold coolant into the motor and hot coolant into the radiator.
Are you using a manual switch to operate the fan or is it wired up to a controller that operates the fan based on the temperature of the radiator? If the fan is manually controlled by you, a automatic controller might be part of the cure (www.dccontrol.com) along with a larger CFM fan
hernandez
44
#12
  • Jan 19, 2006
  • #12
i took off the underdrive pullies and it stil gets hot. the fan shroud doesn't cover up enough of the radiator, and it is wired up so that it turns on at 170 and off at 160
hernandez
44
#13
  • Jan 19, 2006
  • #13
it is wired so it turns on at 170 degrees in the radiator, and it is 2500cfm i think
sgarlic
3,085
Jan 19, 2006
#14
  • Jan 19, 2006
  • #14
Is this all based on the readings of the stock gauge, or an aftermarket gauge?
Modular2v
3,222
23
99
oklahoma
Jan 19, 2006
#15
  • Jan 19, 2006
  • #15
i wouldnt trust the stock guage.....go buy an aftermarket one
srothfuss
Oct 17, 2004
1,796
Woodward Ave.
Jan 19, 2006
#16
  • Jan 19, 2006
  • #16
It has to be the fan that is causing your problems then.... There are plenty of good choices out there to correct your issues.
HISSIN50
34
129
Jan 19, 2006
#17
  • Jan 19, 2006
  • #17
So um, with your 180* stat, your fan should be running almost constantly once up to temp. Is it doing that?
One generally wants the fan to come on ~12-15* hotter than the stat rating and off at 5-8* hotter than the stat rating. E.g., with a 180 stat, the fan comes on at 195 and goes off at 187 (that general idea).
hernandez
44
#18
  • Jan 19, 2006
  • #18
all of the readings is from the stock gauge, but i went to the junk yard and found a decent efan from a 92 ford tempo, i did the install and man it really helped out alot, it doesn't overheat but still gets a little hot, i will adjust the settings to about 195 to turn on the fan and 185 to turn it off, does that sound good
HISSIN50
34
129
Jan 19, 2006
#19
  • Jan 19, 2006
  • #19
How do you know what temps you are setting the fan to go on and off at, if you dont have an aftermarket gauge?
The fan still might not turn off in the summer, depending upon the brand of t-stat used. Some dont open near their rated temp. I should have previously stated that in my example, a pre-requisite would be using a balanced t-stat.
But that general idea sounds real good to me (if you notice the fan not going off, bump up the off-temp on your controller.
You will have to wait for summer to see how that fan does for you (arent Tempo's 4 cylinder motors?).
Good luck.
hernandez
44
#20
  • Jan 23, 2006
  • #20
yeah the ford tempo is a 4 banger but the fan is doing its job. and it fits pretty good on the radiator, just needs to be like a inch and a half wider to cover the whole radiator core, but thanx for the helping info and i will have to wait till summer to see how she runs
Engine 1986 GT Overheating issues
  • 86 5O GT
  • Jan 25, 2026
Fox 5.0 Mustang Tech Jan 29, 2026
86 5O GT
Engine Themostat
  • Mindseye007
  • Jan 30, 2026
Fox 5.0 Mustang Tech Feb 1, 2026
86HO5.0
Electrical Lincoln Mark VIII Replacement Fan Motor
  • AeroCoupe
  • Sep 26, 2026
Fox 5.0 Mustang Tech Sep 26, 2026
AeroCoupe
J
V-6 thermostatically controlled cooling fan - on when cold - new behaviour
  • jacekk
  • Oct 1, 2025
  • 2005 - 2014 Specific V6 Tech
2005 - 2014 Specific V6 Tech Saturday at 12:08 PM
jacekk
J
F
Overheating after ECU flash
  • fourtyfour338
  • Jul 23, 2025
1996 - 2004 SN95 Mustang -General/Talk- Jul 23, 2025
