Emergency Brake Cables
  • Thread starter Thread starter pj1
  • Start date Start date Jan 3, 2008
P
pj1
57
Calif
Jan 3, 2008
  • Jan 3, 2008
Hi, I've got a '65 Vert. While I haven't posted much, I've been reading and learning for a number of years.
I recently put on X exhaust pipes.
The E brake cables are routed thru the drive shaft tunnel, and to a U shaped device. The problem, is that each cable lies across about 1 foot of exhaust pipe. The cable coating quickly burns and eventually the wire breaks.
While the car is a '65, it appears the the leverage arm which the U shaped device is conntect to, is from a '66. I believe that a '65 has 2 separate E brake cables.
I think all I need to do is wrap the 1 foot of exhaust pipe. Then the wire can lay on the wrapping and then I'm off to the next project.
This can't be a unique problem.
Thanks
M
mysavioreigns
23
Arlington, TX
Jan 4, 2008
  • Jan 4, 2008
Dang, your exhaust must be hot. My parking brake cable (it's not an E-brake) never worked and kept hittin the driveshaft, so I tied it to the exhaust pipe. No problems...
It's made of steel cable, how did it break?
BullittStangV8
1,104
NJ
Jan 4, 2008
  • Jan 4, 2008
The 65 and 64.5 do have two seperate e-brake cables.
Cobain03
996
Lexington, Ky
Jan 4, 2008
  • Jan 4, 2008
one cable goes to each wheel and tie together in the middle on my 65. It has that u shape device that connects them and thats where you adjust it too.
M
mustangdave
My rearend needs a stud and two nuts.
2,976
North Carolina
Jan 4, 2008
  • Jan 4, 2008
Personally, I would modify the exhaust so it didn't touch. BTW mysavioureigns, if you don't think think the parking brake is an E-brake, what are you going to do if the brakes fail? open the door and drag your feet?
Cobain03
996
Lexington, Ky
Jan 5, 2008
  • Jan 5, 2008
Flintstone it! lol
P
pj1
57
Calif
Jan 6, 2008
  • Jan 6, 2008
Thanks for the help
mysavioreigns - both cables insulation were melted to the pipe. The next step would be for the cable itself to burn/break. The car is mainly driven in the mountains. Lots of full throttle time. Maybe that generates more heat?
I'm going to put a spring connected to the top of the driveshaft tunnel and the ebrake cable. That will hold the cable off the pipes and let the cable straighten out when in use, with no cable binding or bends.
In addition, I'm going to wrap the pipe for about 1 foot. That's should fix it.
I'm not sure how I can redo the exhaust pipes. They sit pretty low already and there just isn't much room in the tunnel for 2 pipes and the drive shaft.
One additional piece of information, the cables seem to have a little too much slack in them. I'm not sure why. But that is probably a contributing factor.
Thanks for the help. I've learned a lot about Mustangs on this forum.
A
Emergency brake causing starting issue, need help.
  • Ace2203
  • Feb 5, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 6, 2025
Mustang5L5
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
What's your tow rig?
  • LILCBRA
  • May 31, 2026
  • Other Auto Tech
Other Auto Tech Oct 4, 2026
JD1964
  • dan50
  • Jul 18, 2026
dan50
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
