Emergency brake light illuminates when I apply the brakes quickly...?
5spd GT
"the 5.0 owns all"
9,516
Arkansas
What could that mean?
It doesn't stay on all the time, but when I hit the brakes kind of hard or quickly it will light up temporarily and then go off after I stop...
Ideas?
Thanks:nice:
This means that your brake fluid is low. Instead of just adding more fluid you should bleed your brakes. Brake fluid is only good for 30k miles tops. Brake issues are a matter of critical safety and importance and must be addressed immediately...
Mine does the same from time to time. There is a small fluid leak coming from the top the left rear caliper where the brake line feeds into it. Very small leak though, havnt added fluid in pobaly 2 weeks or so.
Exactly, also check your pads. One reason your fluid could be low is if your pads need replaced or are close to needing replaced.
