emergency flashers
  • Thread starter Thread starter steemin
  • Start date Start date Nov 28, 2005
steemin
201
Ft. Wayne Indiana
Nov 28, 2005
  • Nov 28, 2005
Finishing up my car.
Did the 65 mustangs come with 4 way emergency flashers?
If so was this standard or an option?
I thought that I had heard/seen a switch installed in the glovebox.
(This is for a restomodded car. Flaming River tilt column if that matters)
Thanks,
Scott
L
limey66
408
Northampton, England
Nov 28, 2005
  • Nov 28, 2005
Apparently came as standard from 66 on - though not on mine...retrofit might be possible, but I think it involves an extra flasher unit, and the switch costs a fortune...
1320stang
4,329
23
89
Edmond, Oklahoma
Nov 28, 2005
  • Nov 28, 2005
'65's didn't have them. My friend had a '66 that had the switch in the glove box. You mentioned that you already have a column, does it have the switch? I'm thinking of installing a late '67 or '68 colapsible column in my car, I believe they have the switch on the column.
65ShelbyClone
4,675
38
119
Antelope Valley, SoCal
Nov 29, 2005
  • Nov 29, 2005
My '68 does. Its a little black pull switch that shuts off when you turn the steering wheel.
I didnt know the '66 switches were expensive. I had one with the black metal plate that ended up as a headlight switch for a Cushman Turf Truckster .
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
  • dan50
  • Jul 18, 2026
dan50
P
LED Flasher EP27 constant clicking problem
  • PSKSAM2
  • Oct 3, 2023
3K
1996 - 2004 SN95 Mustang -General/Talk- Oct 19, 2023
PSKSAM2
P
R
Electrical Trunk Mount Battery and Cut Off Switch- Need Help
  • Rcdgl
  • Nov 20, 2024
Fox 5.0 Mustang Tech Nov 20, 2024
nickyb
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
