Emission test
  • Thread starter Thread starter rwood126
  • Start date Start date Sep 10, 2010
R
rwood126
161
mCdONOUGH, GA.
Sep 10, 2010
  • Sep 10, 2010
My 89 GT vert just past with flying colors . Emmisions man said it has better #'s than some of the newer cars he's done.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 10, 2010
  • Sep 10, 2010
Tell us about what emissons gear is or isn't on your car and what mods you have. It will help some of the other guys know what they need to do to get their cars to pass emissions testing.
R
rwood126
161
mCdONOUGH, GA.
Sep 11, 2010
  • Sep 11, 2010
I have GT 40 heads, cobra intake, E-cam, high flow cats.
All other emmision parts are still on the car.
Mustang5L5
Mod Dude
Feb 18, 2001
43,392
18,135
224
Massachusetts
Sep 11, 2010
  • Sep 11, 2010
Iirc, pre-90 mustangs have looser limits needed to pass emissions, in 1990, things started to get more strict which is why ford started revising the ho camshaft.
So when it comes to molding mustangs, it's easier to make a 1988 pass the sniffer than a 1992. Same car, but different limits used
BiminiBlueLX
37
Tucson, AZ
Sep 11, 2010
  • Sep 11, 2010
So, would you say a '91 consisting of a TFS Street Heat intake, Twisted Wedge heads, and an Anderson N-41 cam pass emissions?
aar0s
1,015
55
69
Sep 11, 2010
  • Sep 11, 2010
man, im glad i dont have to worry about this...yet.
MFE92
1,094
373
124
Phoenix
Sep 12, 2010
  • Sep 12, 2010
I just had mine tested and passed on Arizona's required dyno test. Mods are in my sig, and the Magnaflow spun-metallic cats have 3 years and 23,000 miles on them.
test...allowed...result
HC......1.00......0.63
CO....12.00......4.16
NOx....2.50......0.82
'92 LX with a 306, untouched GT40 irons, Cobra intake, FRPP 65mm TB, Pro-Flow 75mm MAF, Comp Cams 270 HR cam, 1-5/8 equal length shorties, Magnaflow spun metallic cats, 2.5 Borla XS w/Dynomax tailpipes.
BiminiBlueLX
37
Tucson, AZ
Sep 12, 2010
  • Sep 12, 2010
Thanks for the info! I appreciate it. I'll have to look into that Comp 270 HR cam. I've got some thinking to do (Trick Flow top end? or Ford Racing top end?)
MFE92
1,094
373
124
Phoenix
Sep 12, 2010
  • Sep 12, 2010
The cam is intended to work with stock style heads. High lift, mild duration. It's not the right cam for big-port heads. The secret is the Magnaflow spun-metallic cats.
MFE92
1,094
373
124
Phoenix
Mar 4, 2012
#10
  • Mar 4, 2012
  • #10
Just tested again yesterday on a dyno-sniffer test. Now they have 4.5 years and 33,000 miles on them, 2,900 of which were under hard-use conditions on road courses, in many case EGT's were hot enough to boil the fuel in the tank thanks to the proximity of the tailpipes. I just passed emissions with them again:
Test...allowed....grams/mile
HC.......1.00........0.64
CO.....12.00........7.77
NOx.....2.50........0.38
stang&2Birds
2,091
New England. :-) CT/MA
Mar 4, 2012
#11
  • Mar 4, 2012
  • #11
FWIW, timing on a 5.0 can also make a huge difference.
I was right at the limit with my timing advanced. With timing set at stock, it passed with flying colors.
I had to dig my timing light out from under a ton of stuff to set the timing.
Setting timing by mechanically and by hand, how *****ing archaic!
Old Skooler
248
43
39
Mar 5, 2012
#12
  • Mar 5, 2012
  • #12
I guess for once in NY were lucky. I just got my 92 inspected on Saturday and 95 or older only has to have a safety inspection and low emissions test. Low emissions means check gas cap and o2 sensors. I had to prove the et streets were street legal (brought in a summit write up) and he looked the other way on the O2 sensors.
I have nothing emissions on my car, so for once NY is easy to deal with
Brake pad and rotor upgrade
  • Sparky714
  • Aug 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Sparky714
2001 SVT Cobra slow return to idle speed
  • phil2001svt
  • Oct 21, 2026
  • SVT Tech Forum
SVT Tech Forum Nov 2, 2026
phil2001svt
D
96 get convertible-sell or part out?
  • DTCstang
  • May 17, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? May 18, 2026
nickyb
G
New Owner: Very Clean 1991 GT Convertible. All original with 21k original Miles. How to make it better?
  • gvanginkel403
  • Oct 30, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 17, 2025
Jarhead67
J
Z
Progress Thread zeth194 - New Guy on the Block
  • zeth194
  • Mar 19, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 26, 2026
LILCBRA
