Emissions Test - New 347 - Clearing Codes
  • Thread starter Thread starter AnthonyR23
  • Start date Start date Jul 17, 2009
AnthonyR23
661
Ontario
Jul 17, 2009
  • Jul 17, 2009
In Ontario we have a tailpipe smog test. I haven't ever heard of anyone failing based on just a visual inspection, just always tailpipe tests and there are a few shops with some pretty friendly people so I can make sure the car stays warm before going in.
So I have about 10 k on my new engine, and have new high flow catalytic converters, all components on the new 347 are emissions legal, camshaft, intake, and heads.. TFS, TFS, and Crane.
I probably should have attempted an emissions on my first 10 day pass but I was trying to work out some codes. Which I still want to clear. So in Ontario you can get an initial test, then pay 100 dollars for a diagnostic. If you pay for that if you spend up to I think 450 or if the repair would cost more than 450 you can get a conditional pass. So pretty much if I have to replace anything emissions related, I might aswell wait till after the diagnostic so that it will at least start adding up to the 450 if its first on the list. That being said, if I could pass the first time that would be great.
Anyone have a 347 with a bunch of components and clear all error codes. Is it still possible to clear all the codes or am I just chasing a dream. I was jumping from 41 to 92, to rich the too lean... With a 13 iac motor error.
So if I were to take it for an emissions my big question is.... what is better for an emissions test.. code 41, 92. At least for the initial. False 41 maybe. Have a crazy clean egr tube and everything is like new, cleaned every part, before it went back on the brand new engine. Everything seems to point to 02 sensors. But it just doesn't make sense to me because I have 4 02's have rotated through them including switching the good one eg. with code 91 over to the 41 side, and still would get 41.. too lean. Then turning up the fuel pressure by say 1 psi at a time until it would jump to 92. Then back down 1 psi, then back to 41.
Any advice regarding codes and wether lean would be better for an emissions or a little rich. Maybe I'm worrying about nothing. May fly past the emissions test with no problems. With everything new. I do think the car needs to be driven, but I only have one 10 day pass. Guess it will be up and down the street till I get some kilometers on it, while crossing my fingers! LOL
Any advice would be much appreciated!! Thanks
mc0311grunt
86
Los Angeles
Jul 17, 2009
  • Jul 17, 2009
personally I would find a smog tech that will "pass" the car for a small fee. There are a lot of those people here in California. Just hard to find. I get asked to do these smogs alot but unless I know the person I won't do it. If not try replacing all the O2's.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 17, 2009
  • Jul 17, 2009
You need to ask the moderator to merge your threads. I have lost track of what you have done, so it makes it hard to give you any specific advice on what to do next.
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
Engine 1988 Ford Mustang throwing 2 OBD-1 codes (32 and 63) rough cold start and initial idle
  • mikeah
  • Nov 16, 2026
Fox 5.0 Mustang Tech Nov 17, 2026
mikeah
M
Progress Thread 1993 Ford Mustang 5.0 convertible stock manual - ODB Codes shows running lean
  • mcalvo
  • Feb 11, 2025
2K
Fox 5.0 Mustang Tech Feb 22, 2025
AeroCoupe
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
L
5.0 Weird Tech Issue
  • Lowpass
  • Jun 9, 2025
  • Other Auto Tech
Other Auto Tech Jun 10, 2025
Lowpass
L
