  • 1994 - 1995 Specific Tech
endless problems...
  • Thread starter Thread starter SS_Eater88
  • Start date Start date Nov 15, 2012
SS_Eater88
Knoxville, TN
Nov 15, 2012
  • Nov 15, 2012
I just got a 1995 GT. Love the car but loaded with problems. I didnt realize it but it had been in a wreck before I got it and Im not sure what all was messed up that wasnt fixed. Today coming down the interstate I went to slow down and when I put on the brakes the car pulled really hard to the right and almost changed lanes for me. What could it be?
madspeed
Colonel Mustard
1,332
204
a van down by the river
Nov 15, 2012
  • Nov 15, 2012
stuck caliper
SS_Eater88
Knoxville, TN
Nov 15, 2012
  • Nov 15, 2012
but wouldnt it do that everytime or just on occasion
madspeed
Colonel Mustard
1,332
204
Nov 15, 2012
  • Nov 15, 2012
could be either, they can be rebuilt or simply replaced, not that expensive. But, test them first!
SS_Eater88
Knoxville, TN
Nov 16, 2012
  • Nov 16, 2012
ok yea I looked them up very inexpensive fix but just hope thats what it is. The biggest part that bothers me is how bad my car rattles. It sounds like its always about to fall apart.
madspeed
Colonel Mustard
1,332
204
Nov 16, 2012
  • Nov 16, 2012
what kind of rattles? Where coming from?
VibrantRedGT
"STANGNET'S PENGUIN SMACKER"
424
154
Boca Raton, Florida
Nov 16, 2012
  • Nov 16, 2012
I wouldn't mess around with a brake problem. Don't wanna get killed or anything. Might want to change the Calipers, Rotors and pads all the way around. Change the calipers in pairs though.
madspeed
Colonel Mustard
1,332
204
Nov 16, 2012
  • Nov 16, 2012
Do you have any experience doing brakes? You can pull them off the rotors and have someone pump the brakes while you look at that rotor, it could be jammed up with something, rare, but ive seen it happen years ago on one of my cars
madspeed
Colonel Mustard
1,332
204
Nov 16, 2012
  • Nov 16, 2012
If it pulled hard to the right, either your left caliper is shot, or, ive seen this happen to my stepson right after he put pads in his truck, put the pads in wrong on one side and they fell out somewhere rending that side useless so pulled to the other side that was working fine. Thats very dangerous as Vibrant mentioned. Check them out asap, you should more than likely be able to see whats going on.
SS_Eater88
Knoxville, TN
Nov 16, 2012
#10
  • Nov 16, 2012
  • #10
I do have some experience with brakes but I just moved so I have no garage or mechanics that I trust to not screw me over. I'm planning on replacing all of that asap. As for the rattles, the front end rattles almost sounds like something or everything is loose or maybe all the bushings shot? Also the rear of the car squeaks while going down the road and def a stiff ride. I just got back from getting exhaust work done and on the passenger side in the rear a bolt from the backside of the rotor going in looked loose and come to find out it was cross threaded
95Vert383AOD
1,133
34
69
New Bedford, MA
Nov 16, 2012
#11
  • Nov 16, 2012
  • #11
When i first got my car i was told by the owner that the rear brakes needed to be done because of a grinding issue. What i found was the pad back plate with no brake material left and the other pad was nowhere to be seen leaving the caliper piston directly making contact with the rotor.
SS_Eater88
Knoxville, TN
Nov 16, 2012
#12
  • Nov 16, 2012
  • #12
When I got mine there was an annoying ding that would keep beeping then go away but sometimes randomly come back and come to find out it was a warning light that they had busted the bulb to so you couldnt tell what it was and after I realized it was a salvage title and had been wrecked I tried contacted him to find out what all was messed up he wouldnt ever respond.
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
Brake pad and rotor upgrade
  • Sparky714
  • Aug 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Sparky714
K
Electrical 2000 GT Intermittent Engine Shutdown In Motion - DTC U1262
  • kenster1092
  • Apr 13, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Apr 24, 2026
squeak93
J
Emission problems
  • jls.zmmr
  • Feb 5, 2026
1994 - 1995 Specific Tech Feb 7, 2026
AeroCoupe
I
98 Mustang GT dying
  • ItsMason
  • May 14, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 25, 2026
lenzgt
L
