Engine Acting Up
  • Thread starter Thread starter Seattle67Fstbck
  • Start date Start date May 26, 2005
Seattle67Fstbck
133
Seattle, Washington
May 26, 2005
  • May 26, 2005
Friend has offered to give me a mid-60's 427 out of his car before it gets "totalled out" (despite damage being minimal). Took a drive in the car, and engine runs smooth until going uphill or giving it some gas. It sounds like it is pinging but then studders and learches and the exhaust note goes from normal to a very low growl. We added an octane booster (thought might help with the pinging) and problem still is present. What would you guys suggest looking at given a short amount of time? I was thinking of checking the floats and fuel filters to see if lack of fuel is causing the issue-
Thanks guys!
iskwezm
4,159
20
79
Rowland Heights,California
May 26, 2005
  • May 26, 2005
Who cares whats wrong with it,just get!!!!.You can probably mess with the timing,maybe has carbon build up on the valves/pistons,needs a tune up and carb adjustment?
Seattle67Fstbck
133
Seattle, Washington
May 27, 2005
  • May 27, 2005
the issue that came to mind is money. If this engine is going to cost me a bunch of cash and/or require a bunch of work that I cannot do myself, then the cost of the engine will not really be worth it (despite how badly I actually want it). What would you guys go about checking first? I thought fuel filter, float, points, and plugs but I am far from an expert. Hence me asking you guys !
geostang351
946
Danb., CT
May 27, 2005
  • May 27, 2005
If it pings as you accelerate, sounds like teh timing is off. This is easy to fix, but need a timing light though and someone who knows how to use it.
D
D.Hearne
11,730
south louisiana
May 27, 2005
  • May 27, 2005
Pinging in a 60's 427 on today's pump gas is something that timing isn't going to fix. Many 427's had 11-12+ to 1 comp ratios. And forget those off the shelf octane boosters, they don't work. You need REAL gas here, as in race fuel or AvGas. As for the problem you described, it's likely the points acting up, if it's still got em. Replace the points with a good electronic setup or a Pertronix unit. There may be tuning problems with the carbs too, especially if it's sat up a lot, but nothing a little TLC can't fix.
Pakrat
3,843
Currently: NH Originally: Rhode Island (and all po
May 27, 2005
  • May 27, 2005
Sounds like a total lost cause and waste of money, can't be fixed, walk away quickly before you lose your shirt.
BTW, where in Seattle is it exactly? Maybe I can dispose of it for him, for a small fee of course. Oh heck, I'm feeling generous, I'll wave the fee.
D
D.Hearne
11,730
south louisiana
May 27, 2005
  • May 27, 2005
I'll be neighborly and also offer my services too
66stangbluework
113
  • May 31, 2005
Hey, Im in tacoma just south of seattle, I would like to buy this engine or get it if possible as my 289 just blew. Please get back to me
  • D Durden
  • Oct 20, 2025
  • 2 3
3K
Swapping a 3.7L v6 into my 1966 Mustang, looking for a bit of ECU info
  • wicked93gs
  • Nov 17, 2019
  • 2005 - 2014 Specific V6 Tech
12K
2005 - 2014 Specific V6 Tech Feb 16, 2022
wicked93gs
M
High RPM Stumble
  • mattmm04
  • Jun 1, 2019
  • SN95 4.6L Mustang Tech
3K
SN95 4.6L Mustang Tech Jun 12, 2019
mattmm04
M
The "Extra Engine" Post....hmmm
  • Wayne Waldrep
  • Jan 17, 2019
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 3, 2020
Wayne Waldrep
H
Engine 90 5.0 LX hesitation under acceleration
  • HarshFyasko66
  • Sep 20, 2018
16K
Fox 5.0 Mustang Tech Sep 27, 2018
HarshFyasko66
H
