  • SN95 4.6L Mustang Tech
engine bay wiring harness question?
  • Thread starter Thread starter 98COBRA281
  • Start date Start date Sep 10, 2008
98COBRA281
1,348
30
59
Port St. Lucie, Florida
Sep 10, 2008
  • Sep 10, 2008
i think i remember reading some where that the wiring harness can be disconnected at the fire wall? i looked all around my engine bay and on the passenger side near the fire wall there is a black box that has all the wires coming out of, is this where it can be unplugged to be able to be removed from the car? i think it would be alot eisier not to have all the wires hanging around when pulling the engine out.....
:SNSign:
Skud
493
Saskatchewan
Sep 10, 2008
  • Sep 10, 2008
Yes, there is one big black box with a 10mm bolt on it. Loosen that bolt and the connector will come out.
There are also two other connectors there in that area and some other ones behind the motor by the transmission.
Unplug the:
COPS
Injectors
Fuel Pressure Sensor
EGR
IAC
TPS
A/C
Cam Position Sensor
Crankshaft Position Sensor
Oil Pressure Sensor
Passenger O2 Sensor
COP harness under the MAF
Two wires on the alternator
Alternator wire on the main fuse box.
Ground wire on the rear of the driver fuel rail.
After that, the wiring lifts right out....
Riley
98COBRA281
1,348
30
59
Sep 11, 2008
  • Sep 11, 2008
Unplug the:
COPS
Injectors
EGR
IAC
TPS
A/C
Cam Position Sensor
Oil Pressure Sensor
Passenger O2 Sensor
Riley
WOW!! thanks
Electrical/engine bay harness questions
  • djj62478
  • May 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 6, 2026
djj62478
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
Electrical Ron Francis Headlight / Alternator Harness
  • dan50
  • Apr 30, 2026
Fox 5.0 Mustang Tech Apr 30, 2026
dan50
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
