  • 1994 - 1995 Specific Tech
Engine Break-in Tips???
  • Thread starter Thread starter OrangeMustangGt
  • Start date Start date Jul 15, 2004
OrangeMustangGt
1,976
Cape Cod, MA
Jul 15, 2004
  • Jul 15, 2004
what should i do when i first fire this thing up? i havent touched the heads, and the engine its self has 55k, so all that is really new is the cam, etc. IS there anything special i should do when i fire her up(if it runs lol)?
M
mackey
1,284
Beverly, Massachusetts
Jul 15, 2004
  • Jul 15, 2004
9. Prelubing the Valvetrain
You are now ready to prelube the valvetrain. Lubricate the rocker arms, springs, and valve stems with about 1/2 quart of oil per head. It is a good idea to use an oil squirt-can to get inside the valve spring and lube the valve stem and seal area.
To ensure long life and trouble-free usage, allow 2-4 hours of normal driving time before running the engine hard. This allows proper break-in of your valvetrain. If you are also breaking in a new cam, it's a good idea to change the oil after a half hour. This will help to remove the many small particles that are shorn off in the break-in process. After proper break-in is complete, you can use a synthetic oil if you wish.
All taken from the trickflow website. Hey your in MA too? Ever go to New England Dragway?
AznStanger3v
2,026
Northern VA
Jul 15, 2004
  • Jul 15, 2004
DRIVE IT LIKE YOU STOLE THE BITCH! jk, dont do that. let it idle for about 15 minutes then take it out for normal cruise lasting between 2-6 hours.
yellow5.0cobra
2,849
In the garage, On the floor.
Jul 16, 2004
  • Jul 16, 2004
i let it sit and idle with 30wt oil for 15min.
i change the oil.
then i pour 10w30, run it for an hour and then change the oil.
then i pour in 10w30 again and drive the car like i stole it.
D
deion82
187
minnesota
Jul 16, 2004
  • Jul 16, 2004
Well a hyd. cam. I run it at 3,000 rpms for 15 mins. Change the oil. Then run it like you stole. Roller cams don't really need any break in period. My race engines run it at 3,500 rpm's or so until the temp hits about 240. water pump is shut off so it only take about 5 to 10 mins. shut it down let it cool completly down change oil retorque heads and double check vavle lash and go racing.
SorsCode
20+ Year Stangneter
Jun 10, 2003
1,024
434
113
St. Louis, MO
Jul 16, 2004
  • Jul 16, 2004
last engine i built i let it run 15 minutes then drained the oil.. put new oil in and drove the crap out of it... takes a few minutes to break the cam in everything else is pretty much broke in, in matter of minutes on a fresh start.
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Tuesday at 2:05 PM
Kleinjj27
K
G
Sup. Just got back into the game with a 1986 4-eye vert.
  • GeorgeG
  • Tuesday at 10:55 AM
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Yesterday at 1:54 PM
limp
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
00 4.6L V8 new clutch won’t go into gear when on?
  • Timboslice
  • Aug 15, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 21, 2026
Oil choice for after break in period.
  • Sask84gt
  • Feb 28, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 14, 2026
Praetorious
P
