Engine bucks when going up a hill
  • Thread starter Thread starter goldfang
  • Start date Start date Feb 6, 2021
G
goldfang
oregon
Feb 6, 2021
  • Feb 6, 2021
89 LX when the engine is lugging when going up a hill the car starts to buck and lose power. If you shift to D2 and the RPM increase it stops bucking. Its like if you had a manual transmission and you where trying to start to move in 4th gear. Dies anyone have any ideas?
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Feb 6, 2021
  • Feb 6, 2021
Are you currently tuning this vehicle yourself with some form of engine management?
G
goldfang
oregon
Feb 6, 2021
  • Feb 6, 2021
No Sir. It hasn't been tuned sense 96. It runs great except for going up hills when its lugging.
C
CarNamedTrouble
Franklin, TN
Feb 13, 2021
  • Feb 13, 2021
My ‘91 Gran Prix had a lose wire in the electrical bundle that did the same thing when driving up a grade. I ended up tying the bundle upward toward the electrical connector to keep pressure off the connector. Never figured out which wire was the problem.
General karthief
Mod Dude
Aug 25, 2016
28,051
10,676
213
polk county florida
Feb 13, 2021
  • Feb 13, 2021
Don't 'lug' the engine, there is a rpm area where the engine works. Then you have gear manipulation that makes it hard on an engine to push the car along, think like starting out in 3rd gear,
Check for codes, there could be codes that have not triggered the cel.
Now would be a good time to tell us it has a 471 GMC blower and ran ten o's in the quarter back in '97.
Oh, changed the plugs lately?
At what RPM is lugging?
Reactions: limp
Mustang5L5
Mod Dude
Feb 18, 2001
43,330
18,058
224
Massachusetts
Feb 13, 2021
  • Feb 13, 2021
So this is an AOD car and you are lugging it up a hill in Overdrive?
I mean, overdrive in an AOD is like 5th gear in the manual trans cars. It’s not meant to go up a hill. With a manual car you would downshift to 3rd or 4th gear to go up a hill. Same with the AOD. It should really be used for highway cruising at speed, and D should be used when driving in hilly areas and towing and such. Pretty sure it states this in the owners manual.
when my car was an AOD, I drove it only in D, and only shifted into OD on the highway. The OD in these trans is rather weak and can burn out with heat, so use it only when the conditions are proper.
D = 1, 2nd and 3rd gear, where 3rd is 1:1 like 4th gear in a manual.
OD adds an overdriven 4th gear equal to 5th in the 5-spd manual.
Reactions: General karthief
General karthief
Mod Dude
Aug 25, 2016
28,051
10,676
213
polk county florida
Feb 13, 2021
  • Feb 13, 2021
I would think if you pushed down on the go peddle when going up hill your trans would down shift.
Mustang5L5
Mod Dude
Feb 18, 2001
43,330
18,058
224
Massachusetts
Feb 13, 2021
  • Feb 13, 2021
It should if the TV cable is adjusted properly, but IIRC from my AOD driving days, you can baby the gas pedal to the point it won’t, especially if you were trying to do something crazy like get decent fuel economy.
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
00 4.6L V8 new clutch won’t go into gear when on?
  • Timboslice
  • Aug 15, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 21, 2026
O
Sooty/Oily Front Engine & Pulleys
  • ozenator
  • Jun 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 22, 2026
Blackhawkxx
K
Severe Drivetrain Shaking
  • KeithM412
  • Jul 5, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 29, 2025
AeroCoupe
