  • SN95 4.6L Mustang Tech
engine build, help needed.
  • Thread starter Thread starter SaleenGT2001
  • Start date Start date Nov 25, 2006
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Nov 25, 2006
  • Nov 25, 2006
i will start ordering parts in the next few weeks. the build will be a few months off still but i need to know what i will be needing. i will be geting the pistons first. most likely manley platinum pistons. do they come with rings? and if they are file fit what specs do i need? plans for the car are for a 550-600 street car. it has a blower and possibly nitrous. i will be installing some cams (recomendations?) and LT's when i do the rest. i think the heads will be stock at least for now.
heres what i have
4.6 cast iron block
cobra crank
manley billet i beam rods
cryo oil pump
canton oil pan
arp head studs
arp main bolts
IW 10% od 8 rib crank pulley
8 rib kit
what other parts do i need and what gaskets should i use on the engine? i know i need some good head gaskets since i will be running close to 20 psi boost. does anyone know where to get cometic gaskets? and will the stock oil pick up tube work on the canton pan?
these are the pistons i am thinking about getting
pistons
any other recomendations?
sorry for all the questions.
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Los Angeles, California
Nov 25, 2006
  • Nov 25, 2006
  • main cap bearings
  • windage tray
as far as the head gasket i would suggest the multi layer steel head gaskets the thickness you would have to factor taht in for the C/R you want
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Nov 25, 2006
  • Nov 25, 2006
what will a windage tray do for me?
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Nov 25, 2006
  • Nov 25, 2006
it helps out on the splash back form the crank hitting the oil in the pan and also frees up HP, also adds some strength to the bottom end
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Nov 25, 2006
  • Nov 25, 2006
consider having all the internals coated with anti friction coatings. all of the racing teams do it and theres power to be had. also cryogenically treating the interanls can help. with those conrods, what bolts are you using? ARP makes ones that are rated to 210,000psi. why are you using main bolts, studs make everything easier. make sure that you get the ARP assembly lube. all of their torque specs require thier lube. also get a bolt stretch gauge for the conrod bolts.
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Nov 25, 2006
  • Nov 25, 2006
the rods have arp bolts with them.
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Nov 25, 2006
  • Nov 25, 2006
i think i will use the MLS Cometic gaskets. thats what MPH uses. the are $120 each so they must be some good ****!
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Nov 25, 2006
  • Nov 25, 2006
well cause i am currently building a 306 for my fox body and the gaskets my friend got me are those multi steel ones and they are $160
ADRENLN
2,342
NJ
Nov 26, 2006
  • Nov 26, 2006
i use the cometic gaskets now, they have been good. im oredring them again when i do the block and blower this summer.
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Nov 27, 2006
#10
  • Nov 27, 2006
  • #10
as far as headers go, which ones will still give me access to the tranny without dropping the headers? remember i have the T56 so i can pull the bell housing seperate from the rest of the tranny.
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Nov 27, 2006
#11
  • Nov 27, 2006
  • #11
what about the SLP LT headers if i remember correctly those give you just enough clearance maybe some else will know because i remember someone mentioning somethign like that about the SLP ones
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Nov 27, 2006
#12
  • Nov 27, 2006
  • #12
i dont believe the SLP ones do. the Bassani Mid-Lengths do, and i think the Hooker ones do as well.
Saleen4971
664
Setauket, LI
Nov 28, 2006
#13
  • Nov 28, 2006
  • #13
go with some VT stage 3 blower cams
jstreet0204
939
Winston Salem, NC
Nov 28, 2006
#14
  • Nov 28, 2006
  • #14
I would suggest getting a kit from summit. You can get different rebuild kits depending on how much you need but it will come with all the rings, bearings, gaskets, freeze plugs, etc. That will cover all the little things you might forget.
DisposableHero
71
#15
  • Nov 28, 2006
  • #15
dude just get VT engines to build you a shortblock.. especially if you're asking what a windage tray is..
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Nov 28, 2006
#16
  • Nov 28, 2006
  • #16
i am building my engine. i have built the 302 for my maverick, the 350 in my blazer and MANY more when i was working at my last job. i have never build an engine that will hold the power that i will be putting in my 4.6.
why would i waste the $2500 in parts that i have sitting in my shop right now and order an engine from someone?
from what it sounds like, a windage tray is the same thing as a main stud gridle right?
Need help ordering a oil cooler and filter relocation kit but don't know what I need
  • Aiden Brown
  • Aug 22, 2026
SN95 4.6L Mustang Tech Sep 14, 2026
squeak93
My next project , a 428 build!
  • horse sence
  • Jul 29, 2026
  • 4 5 6
2K
Classic Mustang Specific Tech Today at 10:23 PM
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
Might have to get a Dart block but don't want to and if I do, then 363 instead of 331. Thoughts on what I've already bought so far.......
  • from6to8
  • Jul 8, 2025
  • 2 3
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 9, 2025
from6to8
