Engine Build Help
  • Thread starter Thread starter new46stang
  • Start date Start date Mar 9, 2008
N
new46stang
146
AZ
Mar 9, 2008
  • Mar 9, 2008
So I'm working on the bottom end of my 331....
First question, how much clearance should I have between the rear counter weight and the main girddle?
http://www.mustangmatty.com/331/girdle1.jpg
Second question, why does this ARP Main Stud (154-5410 Ford 302 main stud kit for girdle) kit have 3 studs shorter than the rest? They also do not have a stud provisioned for the oil pump pickup tube nut. The 3 that are shorter have a 12pt nut instead of a 6pt nut. In this pic:
http://www.mustangmatty.com/331/girdle2.jpg
You can see the smaller stud is about 3 threads too short. Should I back the stud out until the nut is flush?
Last question, I have spacers under the girdle and have at least .002in clearance between the cap and the girdle except #5. There is a raised letter in the way. Should I just grind it off and shoot for a couple thou clearance?
TIA,
Matt
Rick 91GT
Mustang Master
95
99
PA
Mar 9, 2008
  • Mar 9, 2008
Matt what brand girdle is that? Is that ARP PT# the one that came with it?
The short stud usually goes under the oil pump so you have proper clearance. You do not want to back the studs out!!!
N
new46stang
146
AZ
Mar 10, 2008
  • Mar 10, 2008
Hey Rick,
The girdle is an unknown brand and I bought the studs separately. The odd thing is that there are 3 short studs, not one. I'm going to call ARP tomorrow to see if the stud set I got is messed up.
Thanks,
Matt
Fast63
717
  • Mar 10, 2008
That counter weight looks wicked close, that doesn't look runnable to me, but I am not an expert when it comes to that.
I agree, there should only be one stud shorter for just under the oil pump, however, if the stud kit is for an older engine with a front sump pan, I could see two shorter studs being used on the rearmost cap to help with clearance with the pan. They still look too short to even use though.
Rick 91GT
Mustang Master
95
99
PA
Mar 10, 2008
  • Mar 10, 2008
Matt the girdle looks like it is either a CAT or a CHP, most girdle companies have studs made for them for the girdle. If ARP can not help you you might want to give CHP or even BBK a call, they both offer similar girdles.
I like to see .100" min between the counterweight or rod bolt and the girdle.
N
new46stang
146
AZ
Mar 10, 2008
  • Mar 10, 2008
Hey All,
Thanks for the help! I'll get a measurement between the counter weight and the girdle when I get home this afternoon and hopefully post the comments from ARP. So to confirm, if the stud is althe way down and the nut is at least flush with the stud we are ok? How about the clearance between top of cap and bottom of girdle? If I have to grind a hair of the cap with that be ok?
Thanks again All.
Matt
P
pistonhead
9
Edmonton, AB, Canada
Mar 10, 2008
  • Mar 10, 2008
That looks really tight, but picture might not do it justice. I also like to see at least, and I mean absolute min, of .100" of clearance. Pull that girdle out and grind yourself some clearance.
N
new46stang
146
AZ
Mar 10, 2008
  • Mar 10, 2008
Ok I called ARP. They will be sending me 2 4 1/2in studs to replace the shorter ones, and I'll keep the one short one for under the oil pump. They are also going to send me a 4 3/4in stud to try to use it for the oil pump pickup tube. The tech I spoke with has had about 3 calls in the last couple weeks on this same kit/issue. He thinks the kit was made for a girdle that does not connect all caps together. He is going to see if he can look into this and fix the stud kit. So, fingers crossed, the stud issue should be fixed. If you need to deal with ARP, Ron Williams is the man!
As for the clearance issues, I guess I'll be grinding.
Oh, on a side note, the first tech I spoke to was kind of a dork so I asked for someone else but he said this as well as Ron (ARP)..... ***only on a iron block ***
you CAN back out the stud if needed. There is only a certain amount of threads that is needed to be screwed into the block. There is a formula that he said but can't remember, something about the percentage of the diameter yadda yadda. For peace of mind...I'll still sink those suckers.
Matt
  • Locked
Engine Might have to get a Dart block but don't want to and if I do, then 363 instead of 331. Thoughts on what I've already bought so far.......
  • from6to8
  • Jul 8, 2025
Fox 5.0 Mustang Tech Jul 8, 2025
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
  • from6to8
  • Jul 8, 2025
  • 2 3
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 9, 2025
from6to8
SOLD SOLD!!!! 1993 Notchback Roadracer For Sale. She's a beast!
  • Boydster
  • Apr 25, 2025
Fox Body Mustangs For Sale (1979-93) Apr 25, 2025
Boydster
