So I'm working on the bottom end of my 331....
First question, how much clearance should I have between the rear counter weight and the main girddle?
http://www.mustangmatty.com/331/girdle1.jpg
Second question, why does this ARP Main Stud (154-5410 Ford 302 main stud kit for girdle) kit have 3 studs shorter than the rest? They also do not have a stud provisioned for the oil pump pickup tube nut. The 3 that are shorter have a 12pt nut instead of a 6pt nut. In this pic:
http://www.mustangmatty.com/331/girdle2.jpg
You can see the smaller stud is about 3 threads too short. Should I back the stud out until the nut is flush?
Last question, I have spacers under the girdle and have at least .002in clearance between the cap and the girdle except #5. There is a raised letter in the way. Should I just grind it off and shoot for a couple thou clearance?
TIA,
Matt
TIA,
Matt
