engine builders....got a question
  • Thread starter Thread starter dragnazz5.0
  • Start date Start date Feb 13, 2006
dragnazz5.0
My "0" key d0esn't w0rk, s0 I have t0 use the zer0
Nov 19, 2005
815
mooresville, nc
Feb 13, 2006
  • Feb 13, 2006
well today in class we were talking about engines. my teacher was talking about how a longer rod is better because it causes the piston to pause or dwell at the top of its travel longer than a shorter rod. so i got to thinking. what is the longest rod you can put in a stock 302 bottom end without notching the cylinders and how much do they generally run for a good set with pistons that have a shorter compression distance? also, since the 351 has a longer stroke...would it work in a stock 302 block? and what would the outcome be? thanks
bluevenom867
I will have images of molesting stuffed animals in
Dec 15, 2003
1,704
St.Petersburg,FL
Feb 13, 2006
  • Feb 13, 2006
Thats not always true.
In high compression motors,a shorter rod helps because it pulls the piston away from the combustion chamber faster (helps with detonation).And at low rpm its not as good because of the longer dwell time at BDC can cause intake revisions.
Its usualy true though that the rod angle is more resistant to side loading and will revv with less "stress" I guess you could say.And at high rpm,the idea is that the longer dwell time let it have a more effienct burn.As it can put more pressure acrosst the top of the piston evenly.
So basicly...dont worry to much about it.Unless your building a Pro Stock or one of them Engine Masters Challenge motor (whitch btw,no one theroy seems to win... ) just dont bother.Go with whats easiest to get a hold of,witch for a 302 thats the 5.09" stock rod.
Black1987Stang
1,422
Jersey Shore
Feb 13, 2006
  • Feb 13, 2006
Sorry cant help u with the 351 rod question, i think the biggest u can take a 302 is a 347.
but theres some disadvantages to it too...Its kinda like the debate from stroking a 302 to a 331 or to a 347...347 would prob make more power but they're not as reliable (not saying it wont last or anything)...My friend told me a whole bunch of disadvantages from the 347 to 331, I think some were something with the wristpins, more pressure on the cylinder walls, lack of lubrication (i forget where), and a few more...if u do a search about 331 VS. 347 im sure youll see some disadvantages.
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
Feb 13, 2006
  • Feb 13, 2006
There is such thing as a long rod 302, using 5.4 rods with shorter pistons. DSS sell them I know.
-add- With a longer rod, you can use a shorter, lighter piston which helps when revving the engine at high speeds.
BaXTeR3221
917
Orange County, NY
Feb 13, 2006
  • Feb 13, 2006
I know they have fixed the wrist pin issue on the 347's. Any good builder can build you a 347 that will last just as long as any other motor.
bluevenom867
Dec 15, 2003
1,704
St.Petersburg,FL
Feb 13, 2006
  • Feb 13, 2006
The shorter piston is also less stable in the bore and doesnt disapate heat as fast.
See?
It can be debated for ever,you'll never know unless you can build two EXACTLY IDENTICAL motors with the only differance in rods and piston hiegth.And run them on the PERFECT dyno,with CONSTANT conditions.
Basicly,pic your theroy and build it
88Stangboy
Banned
Dec 12, 2005
342
Greenville, SC
Feb 14, 2006
  • Feb 14, 2006
ive heard that "theory" about long rods to.
But unless your building a extremely high hp engine for racing your not going to see a difference. In my mind, i may be wrong, but why would piston dwell time even matter? The valve still stays open the same amount of time, so unless you increase duration, how does that help with filling the chamber more or whatever? I wouldn't waste my time with longer rods, there is no point in my mind.
dragnazz5.0
Nov 19, 2005
815
mooresville, nc
Feb 14, 2006
  • Feb 14, 2006
does anyone know anything about using a 351 crank in a 302 block?
Rick 91GT
Mustang Master
95
99
PA
Feb 14, 2006
  • Feb 14, 2006
Yep you can build a long rod 302 or 306 using a 5.4" rod, still may need to clearance the walls a hair depending on the rod bolt design.
Rick 91GT
Mustang Master
95
99
PA
Feb 14, 2006
#10
  • Feb 14, 2006
  • #10
Not possible, the 351W has a 3.00" main, the 302W has a 2.249" main...
dragnazz5.0
Nov 19, 2005
815
mooresville, nc
Feb 14, 2006
#11
  • Feb 14, 2006
  • #11
oh ok...i must have misread the info or it was wrong on the website i looked at
dragnazz5.0
Nov 19, 2005
815
mooresville, nc
Feb 14, 2006
#12
  • Feb 14, 2006
  • #12
couldnt you just cut the main down to 2.249? i dont see why it would be a problem since the 302 has that size main
90mustangGT
2,773
17
89
Dallas, GA
Feb 14, 2006
#13
  • Feb 14, 2006
  • #13
I know, and all that work and your just one crank away from a 347. Unless your class limited, it just sounds stupid to me.
It will still have more piston than a 347, wouldn't it?
Rick 91GT
Mustang Master
95
99
PA
Feb 15, 2006
#14
  • Feb 15, 2006
  • #14
You could cut the crank, pay to have it rehardened etc... But why? You could buy a aftermarket crank at half of that price. Plus with a 351 it has a 3.5" stroke, you would need to come up with a weird rod and piston combo to try to make it work.
dragnazz5.0
Nov 19, 2005
815
mooresville, nc
Feb 15, 2006
#15
  • Feb 15, 2006
  • #15
well than you would have to get a taller deck block. im just trying to figure out if it would make a decent motor or not. its only 1/10th of an inch longer stroke than a 347 stroker so you could use a stock 5.09" rod with the 3.5" stroke instead of the 3.4" stroke and 5.4" rod
Rick 91GT
Mustang Master
95
99
PA
Feb 15, 2006
#16
  • Feb 15, 2006
  • #16
It isn't that easy... First a 302W block only comes in a 8.2 deck or if you go with a race block you can go 8.7". You can not just put a 5.09" rod and a 1.35" CH piston in that 8.2" motor since you would have interference problems with the piston contacting the crank. You may be able to come up with a crazy custom piston and a rod to work but it would not be worth it. If I was building a 8.7 block I would use something different as well. You would be surprised what .100" does to a rotating assembly. Plus like I already posted turning it down and reheat treating that crank really isn't the best, and it isn't cheap. I really do not think you can turn down a 3" main to a 2.25" main, it is hard enough to get a billet piece changed from a 3" main to a 2.749" Clevland main, and that's a good quality crank.
For all the money and custom parts it would take it is much easier and cost efficent to stay with a 3.25" stroke or 3.4" stroke set-up.
dragnazz5.0
Nov 19, 2005
815
mooresville, nc
Feb 15, 2006
#17
  • Feb 15, 2006
  • #17
ok...well i guess you made a better point that i ever could have hoped to make. thanks for the info rick
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
J
'96 Cobra: A/C gets weak and engine misfires under load when warm
  • jruhnke
  • Oct 22, 2025
  • SVT Tech Forum
SVT Tech Forum Nov 20, 2025
nickyb
Engine 302 production block selection
  • FastDriver
  • May 19, 2024
  • 2 3
8K
Fox 5.0 Mustang Tech Jul 1, 2025
FastDriver
Bought an engine for my project
  • 2stroke1971
  • Jul 7, 2024
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 9, 2024
limp
