Engine code Help??
Haus
408
ok first off that jumper wire process to count the egine light works awesome. :nice:
ok i did the KOEO and the KOER tests and this is what i got.
KOEO- codes 51 and 66
KOER- codes 21, 94 and 44.
any help with these codes.
52 (o): PSPS (Power Steering Pressure Switch) circuit open. Suspect PSPS, harness. (r): PSPS did not change states. - Check your power steering pump switch and probably get a new switch.
66 Vane Air Flow (VAF) or Mass Air Flow (MAF) signal low - VAF MAF -- clean your MAF sensor
21 - Engine Coolant Temperature (ECT) sensor out of range - ECT -- Go buy a new one and replace it.
94 - AIR system inoperative - Air Injection -- Not sure, perhaps some else can help more.
I'm learning about the codes now, I'm waiting for my book to come in to learn about the codes more and tuning the EEC-IV.
Thanks
Code 21 – ECT sensor out of range. Broken or damaged wiring, bad ECT sensor.
Note that that if the outside air temp is below 50 degrees F that the test for the
ECT can be in error.
The ECT sensor has absolutely nothing to do with the temperature gauge. They are
different animals. The ECT sensor is normally located it the RH front of the engine in
the water feed tubes for the heater.
The ACT & ECT have the same thermistor, so the table values are the same
ACT & ECT test data:
Use Pin 46 on the computer for ground for both ECT & ACT to get most accurate
readings.
Pin 7 on the computer - ECT signal in. at 176 degrees F it should be .80 volts
Pin 25 on the computer - ACT signal in. at 50 degrees F it should be 3.5 volts. It is
a good number if the ACT is mounted in the inlet airbox. If it is mounted in the lower
intake manifold, the voltage readings will be lower because of the heat transfer.
Voltages may be measured across the ECT/ACT by probing the connector from
the rear. Use care in doing it so that you don't damage the wiring or connector.
Here's the table :
68 degrees F = 3.02 v
86 degrees F = 2.62 v
104 degrees F = 2.16 v
122 degrees F = 1.72 v
140 degrees F = 1.35 v
158 degrees F = 1.04 v
176 degrees F = .80 v
194 degrees F = .61
Note that all resistance tests must be done with power off. Measuring resistance
with a circuit powered on will give false readings and possibly damage the meter.
Ohms measures at the computer with the computer disconnected, or at the sensor
with the sensor disconnected.
50 degrees F = 58.75 K ohms
68 degrees F = 37.30 K ohms
86 degrees F = 27.27 K ohms
104 degrees F = 16.15 K ohms
122 degrees F = 10.97 K ohms
140 degrees F = 7.60 K ohms
158 degrees F = 5.37 K ohms
176 degrees F = 3.84 K ohms
194 degrees F = 2.80 K ohms
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds
(website host) for help on 88-95 wiring http://www.veryuseful.com/mustang/tech/engine/
Code 51 Engine Coolant Temperature (ECT) sensor signal is/was too high -
Possible bad ECT sensor, or wiring. Possible missing signal ground –
black/wire wire broken or bad connection. With the power off, measure the
resistance between the black/white wire and battery ground. You should see
less than 1 ohm. Check the same black /white wire on the TPS and MAP
sensor. More than 1 ohm there and the wire is probably broken in the harness
between the engine and the computer. The 10 pin connectors pass the
black/white wire back to the computer, and can cause problems.
Voltages may be measured across the ECT by probing the connector from the rear.
Here's the table :
194 degrees F = .61
Ohms measures at the computer with the computer disconnected, or at the sensor with
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring http://www.veryuseful.com/mustang/tech/engine/
Code 66 MAF below minimum test voltage.
Insufficient or no voltage from MAF. Dirty MAF element, bad MAF, bad MAF wiring, missing power to MAF. Check for missing +12 volts on this circuit. Check the two links for a wiring diagram to help you find the red wire for computer power relay switched +12 volts. Check for 12 volts between the red and black wires on the MAF heater (usually pins A & B). while the connector is plugged into the MAF. This may require the use of a couple of safety pins to probe the MAF connector from the back side of it.
There are three parts in a MAF: the heater, the sensor element and the amplifier. The heater heats the MAF sensor element causing the resistance to increase. The amplifier buffers the MAF output signal and has a resistor that is laser trimmed to provide an output range compatible with the computer's load tables.
The MAF element is secured by 2 screws & has 1 wiring connector. To clean the element, remove it from the MAF housing and spray it down with electronic parts cleaner or non-inflammable brake parts cleaner (same stuff in a bigger can and cheaper too).
The MAF output varies with RPM which causes the airflow to increase or decease. The increase of air across the MAF sensor element causes it to cool, allowing more voltage to pass and telling the computer to increase the fuel flow. A decrease in airflow causes the MAF sensor element to get warmer, decreasing the voltage and reducing the fuel flow. Measure the MAF output at pins C & D on the MAF connector (dark blue/orange and tan/light blue) or at pins 50 & 9 on the computer.
At idle = approximately .6 volt
20 MPH = approximately 1.10 volt
40 MPH = approximately 1.70 volt
60 MPH = approximately 2.10 volt
Check the resistance of the MAF signal wiring. Pin D on the MAF and pin 50 on the computer (dark blue/orange wire) should be less than 2 ohms. Pin C on the MAF and pin 9 on the computer (tan/light blue wire) should be less than 2 ohms.
There should be a minimum of 10K ohms between either pin C or D on the MAF and ground.
http://www.veryuseful.com/mustang/tech/engine/images/88-91eecPinout.gif
Codes 94 & 44 - AIR system inoperative - Air Injection. Check vacuum lines for leaks, & cracks. Disconnect the big hose from smog pump: with the engine running you should feel air output. Reconnect the smog pump hose & apply vacuum to the first vacuum controlled valve: Its purpose is to either dump the pump's output to the atmosphere or pass it to the next valve. The next vacuum controlled valve directs the air to either the cylinder heads when the engine is cold or to the catalytic converter when the engine is warm. Disconnect the big hoses from the back side of the vacuum controlled valve and start the engine. Apply vacuum to the valve and see if the airflow changes from one hose to the next.
The two electrical controlled vacuum valves mounted on the rear of the passenger side wheelwell turn the vacuum on & off under computer control. Check to see that both valves have +12 volts on the red wire. Then ground the white/red wire and the first solenoid should open and pass vacuum. Do the same thing to the light green/black wire on the second solenoid and it should open and pass vacuum.
Remember that the computer does not source power for any actuator or relay, but provides the ground necessary to complete the circuit. That means one side of the circuit will always be hot, and the other side will go to ground or below 1 volt as the computer switches on that circuit.
The computer provides the ground to complete the circuit to power the solenoid valve that turns the vacuum on or off. The computer is located under the passenger side kick panel. Remove the kick panel & the cover over the computer wiring connector pins. Check Pin 38 Solenoid valve #1 that provides vacuum to the first Thermactor control valve for a switch from 12-14 volts to 1 volt or less. Do the same with pin 32 solenoid valve #2 that provides vacuum to the second Thermactor control valve. Starting the engine with the computer jumpered to self test mode will cause all the actuators to toggle on and off. If after doing this and you see no switching of the voltage on and off, you can start testing the wiring for shorts to ground and broken wiring. An Ohm check to ground with the computer connector disconnected & the solenoid valves disconnected should show open circuit between the pin 32 and ground and again on pin 38 and ground. In like manner, there should be less than 1 ohm between pin 32 and solenoid valve #2 and pin 38 & Solenoid valve #1.
If after checking the resistance of the wiring & you are sure that there are no wiring faults, start looking at the solenoid valves. If you disconnect them, you can jumper power & ground to them to verify operation. Power & ground supplied should turn on the vacuum flow, remove either one and the vacuum should stop flowing.
Two of the codes, 21 & 51, suggest a wiring problem with the signal ground (black/white wire). Be sure to do the resistance checks on the signal ground wire before you spend any money on new sensors.
thanks for the info. i really appreciate it. :nice:
ok trying to rack my brain trying to figure out the write up on the 94 and 44 codes. once it got light out this morning i went out and looked at my stang and i took pics.
Are these the two electrical controlled vacuum valves??
And this pic is the 2nd Bypass valve im guessing. there is a vacuum line come off of it and going through the vacuum tree and a line coming out of it going in to something on one of the electrical controlled vacuum valves. and there is a line coming out of it but it is not connected to piece you can see in the 3rd picture.
and the first smog pump bypass valve there is a vacuum line going to the Vacuum tree and a line coming out of it going into the electrical controlled vacuum valve but in the 4th pic you can see that the line that come out of it is not connected.
now do those two lines that are Broken/disconnected that come out of the electrical controlled vacuum valves go into the double fitting thats shown in picture 3??? and could those Disconnected/broken vacuum lines cause the codes 94 and 44??
Yes, the two bottom ones are the valves.
Here's a diagram of the system:
There is another vacuum diagam that might be helpful as well. I recommend that you spend some time that the above web site link. There is some excellent information available there.
thanks. ill check have to find a way to put that vacuum hoses back in there. its gonna be hard concidering not that much room and big hands. the way it looks seems like i can take off the wheel well cover and get to it that way.
and for the Maf code. could it trip a code if i started my engine with out the maf plugged it. figured i had it unplugged and then put it back on and the car ran alot better. could that trip the code i got???
and the ECT makes sense. i thought i had that problem all along since i have warm/hot start problems at times. ill check the volts to the wires and if all good ill replace the ECT.
well i put back on the vacuum lines coming out the two electrical controlled vacuum valves to the vacuum fitting in the fender area. disconnected the battery, connected it about 20 mins later and drove around for 5 mins.(cant drive to much since its not legal to be driving on the road right now)
checked the codes again and for KOEO i got the following
Blink pause blink a little longer pause blink pause blink 4 second pause blink 5-6 second pause blink pause blink little longer pause blink pause blink.
so it looked like this 11..11....1......11..11
and KOER i just got code 21(which is still the ECT code. but no Maf code or the 44 and 94 code or the other ECT code.
