  • SN95 4.6L Mustang Tech
engine codes help
  • Thread starter Thread starter 98stangv8
  • Start date Start date Jul 22, 2005
98stangv8
1,036
fayetteville, nc
Jul 22, 2005
  • Jul 22, 2005
check engine light on...codes that came up are P0351, P0352, and P0354. The person at Autozone said they were Ignition coil A, B D circuit problems....any help on what that means. I saw on the sticky, but that didn't help much....are these the passenger or driver coils? When I drive, there is a noticable delay (occuring more the more I drive now) when I hit the gas, and sometimes it won't acknowledge the pedal being pressed...
any help would be great!
R
Roger_4.6_96
1,209
Reno,NV
Jul 23, 2005
  • Jul 23, 2005
I would just change coil packs, wires and spark plugs. If you cant afford them all just get some coil packs see if it fixes problem.
98stangv8
1,036
fayetteville, nc
Jul 24, 2005
  • Jul 24, 2005
does anyone know if the a, b and d are the passenger or driver side coil packs?
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Jul 24, 2005
  • Jul 24, 2005
Measure resistance of all coils with between the coil driver pins on the coil pack itself and IGN Start/Run circuit at Coil harness connector.
Is resistance less than 5 ohms?
if you take the connector off the coil pack the two outer pins are the coil driver pins with the center being the IGN start/run. you want too connect one test lead too the CD pin ( pick one of them,then do the other) and place the other test lead too the center wire in the harness connector you removed from the coil pack.. do this for both outer wires.. for both coils.
that tests the primary side of the coil
Remove both plug wires from secondary of Coils
Measure resistance of Coil secondary between coil pack towers.
Is resistance between 12K and 14.5K ohms?
all you do to do this test is remove the wires.. and with the connector of the coil facing you.. connect one test lead to the top wire tower. and the other too the bottom wire tower.. then do this on the other side of that pack.. and the same for the other coil pack..
if the coil packs fail any of these tests replace them.. if not. . check back in you could have PCM driver problems or wirring problems.
98stangv8
1,036
fayetteville, nc
Jul 25, 2005
  • Jul 25, 2005
dang...I think I will just buy new coil packs...only $100...I had the screamin' demon ones...they had a slight crack in the side...that may have gone through and caused some problems..
K
Electrical 2000 GT Intermittent Engine Shutdown In Motion - DTC U1262
  • kenster1092
  • Apr 13, 2026
SN95 4.6L Mustang Tech Apr 24, 2026
squeak93
P
2000 GT Random Power Loss
  • Pinellas50
  • Mar 9, 2026
SN95 4.6L Mustang Tech Mar 23, 2026
Pinellas50
P
  • Gulftown980x
  • Jul 29, 2026
squeak93
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
A
Check Engine codes jumping around
  • azactor
  • Jan 9, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 24, 2026
DadLife0724
