Engine Combination Help
  • Thread starter Thread starter Matty469
  • Start date Start date Sep 24, 2005
Matty469
77
Hawaii
Sep 24, 2005
  • Sep 24, 2005
I am trying to find the best combinations to accomidate the Holley Systemax II engine package I purchased for my 91 GT. Right now I already have (to go with it) 70mm Throttle Body/EGR, 155lph fuel pump, 24# Injectors, 70mm Mass Air, 1 5/8"Long Tube Headers/H-Pipe/Flowmaster, underdrive pulleys, and 200 amp one wire altenator. I think these are good. But I am not sure which rockers to go with. Any suggestions on what I already have and what else I should get would be great. Any advise or comments would be great. Thanks
Grn92LX
Fidanza Man!
6,819
64
129
New York
Sep 24, 2005
  • Sep 24, 2005
Pick up a set of 1.6 roller rocker. I think those heads use 3/8" studs (find out before ordering rockers). Combo looks good, but I hear the camshaft isn't the greatest. I know Rick 91GT on here made 340rwhp with that combo but with an afm n-61 cam. You'll need new pistons or cut stockers to work. Just an example.
What 70mm maf is that? Is that the cobra one, if so you need a cobra eec to use it.
Matty469
77
Hawaii
Sep 24, 2005
  • Sep 24, 2005
I bought it while in Iraq online, just looked at it, realized it is a C&L MAF for 24# and is 76mm.
Paul Perreca
1,085
  • Sep 24, 2005
crane 1.6 less of a chance you'll run into clearance issues...
Paul Perreca
Matty469
77
Hawaii
Sep 24, 2005
  • Sep 24, 2005
Probably have to go with a set of tall Valve covers with the roller rockers?
Matty469
77
Hawaii
Sep 24, 2005
  • Sep 24, 2005
And maybe an intake spacer?
Rick 91GT
Mustang Master
95
99
PA
Sep 25, 2005
  • Sep 25, 2005
What heads do you have PT#???
The cam will not give you the results you want, going with a AFM cam on a custom would work very well. If you have stock pistons the AFM N-41 would work I believe that is the one Rick specs in for that kit. If you have aftermarket pistons or notch them the N-61 works great!
I ran a 30# inj (I was at 80% duty cycle with them...)(24# is tooo small)
75mm TB
80mm Pro-M shorty (this worked better then the 76mm C&L I had)
1.6 rockers (I like the Scorpions or the new lightweight profiled Probes)
I cleaned up the heads a little and matched the ports on the upper to lower. I needed 1" spacer and 4 gaskets! to clear the tall valve covers.
If you need any specific help or parts let me know if Ic an help you.
Here's a pic of the old combo... I miss it to tell you the truth, the car was a blast and on a 175 shot it made 550RWHP+/742RWTQ. I'm actually thinking about building another street car since my car is far from one now.
Matty469
77
Hawaii
Sep 25, 2005
  • Sep 25, 2005
75mm TB
Can't find a PT#. Let me know where to look. I have them in hand at the moment. This is all stuff I bought while in Iraq. Trying to fix up my first stang I bought in 99. This is the car I'll never get rid of.
Engine 91 mustang 302 Low acceleration car backfires pops and acts like it doesn’t want to take fuel
  • 1991Fox5.0
  • Oct 4, 2025
Fox 5.0 Mustang Tech Oct 6, 2025
1991Fox5.0
M
Please help me identify this.
  • MattyB77
  • Jul 2, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 4, 2026
gkomo
Help! Fox with idle issues
  • bbarton
  • Sep 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 12, 2026
AeroCoupe
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
W
Electrical 91 GT Alternator Replacement Question
  • willrh111
  • Oct 22, 2025
Fox 5.0 Mustang Tech Oct 23, 2025
nickyb
