Engine Coolant Drain Plug Stuck
  • Thread starter Thread starter geordie
  • Start date Start date Apr 11, 2005
G
geordie
576
  • Apr 11, 2005
I need some ideas guys. My engine drain plug must be fused to the block. I've snapped one easy out, drive in type, trying to get it out. I managed to remove the reminder of the easy out with a Dremmel. I tried again to remove the plug with a left handed thread easy out and I think that I am close to snapping that one. I used penetrant oil and heat.......nothing. I am starting to think that the PO might have epoxied the plug in for some reason.
My alternatives seem to be:
1. Dremmel as much as I can of the plug out, and then try and collapse it. Problem is, if the plug threads are fused together then I can't see how I will be capable of collapsing it.
2. Drill out the old plug and retap the hole and fit with a larger plug. Any suggestions on thread type, tapered hole/tapered plug or straight hole with tapered plug.
Which alternative should I go for, or does anyone have any other bright ideas.
krash kendall
1,258
Aldergrove, B.C. Canada
Apr 11, 2005
  • Apr 11, 2005
The threaded easy outs are impossible to get out if you break them. Try drilling it as close to the minor diameter of the thread size as you can (or use your dremel). If you get it reasonably close to center you can get remaining threads of the plug out with a sharp pick and then clean it out with the original tap size.
G
geordie
576
  • Apr 11, 2005
Sounds like a plan. Does anyone know what the original 302 engine drain plug female thread size was. It looks like 1/4 inch NPT taper with a straight plug but I didn't think that this was a preferred solution for sealing. I thought that the right way was a stright hole with a tapered plug.
D
D.Hearne
11,730
south louisiana
Apr 11, 2005
  • Apr 11, 2005
Just me, But I've never been able to remove any coolant drain plug from a Ford. Next time leave it be. And good luck on getting the remainder of the old one out.
P
paintballtommy
244
concord, ca
Apr 12, 2005
  • Apr 12, 2005
what he said. i was never able to get mine out of an old 289 either. worst case scenario. drill it out a size larger. tap and helicoil it. should solve your problem.
65ShelbyClone
4,675
38
119
Antelope Valley, SoCal
Apr 12, 2005
  • Apr 12, 2005
The problem is using an iron plug in an iron block. If you get it out, replace it with brass or stainless.
G
geordie
576
  • Apr 12, 2005
Thanks guys. Good tip on the use of a brass or stainless plug, thanks.
A machinist work colleague has advised me to drill out the remainder of the plug using the correct drill for a 1/4 NPT tap, which is 7/16 inch. If I can get the drill centered than this should bring me to the minor diameter of the block thread. Then re-tap the thread. Now this is the bit that's confusing me. Re-tapping the thread is going to cut a new thread which is unlikely to follow the original thread, so as far as I can see I'm going to end up with partial threads, if the rest of the plug falls out. I can only see this working if I tap the thread deeper than the old one, into new block iron, which will draw the plug in deeper, taper thread remember.
Does this seem sensible? Comments please, I really want to get this straight in my head before I attempt a repair.
Per the previous comment about helicoils. As the block is iron, I assume that I would only need to use a helicoil if I wanted to use the existing plug size.
krash kendall
1,258
Apr 12, 2005
  • Apr 12, 2005
You can't helicoil a tapered thread (as far as I know). When you drill out the minor diameter you should be able to peel the remainder of the plug out.
66HertzClone
428
Central New Jersey
Apr 12, 2005
  • Apr 12, 2005
If I were you I would install a 1/4 radiator petcock in the block after you get the original plug out. Sure makes service in the future very easy to do.
D
D.Hearne
11,730
south louisiana
Apr 12, 2005
#10
  • Apr 12, 2005
  • #10
One way to get the remainder out is to use a cutting torch. It'll burn out the steel leavings and leave the iron alone.
G
geordie
576
#11
  • Apr 12, 2005
  • #11
Plan for tonight is to buy a 'yellow' (hotter flame) tank for the propane torch. Heat the heck out of the plug in hopes of burning whatever crap, rust etc in in the threads. Try and locally cool the plug and give it one last go with the easy out, being careful not to snap it.
If that fails, drill out as much as I can of the plug and see if I can pick out the remianing plug threads.
I that don't work, drill and tap the hole the next biggest size for which I can get a stainless steel pet **** or plug.
G
geordie
576
#12
  • Apr 15, 2005
  • #12
The plug is out!
Carefully applied more heat last night and then literally dripped ice water on the plug itself. I was then able to remove it with a left handed 'easy out'.
I then cleaned out the threads with a thin rotating wire brush using my drill and ran the tap down the thread.
Thanks for the advice guys.
krash kendall
1,258
Apr 15, 2005
#13
  • Apr 15, 2005
  • #13
Good job! It's quite a relief when something like that is over with.
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
  • dan50
  • Jul 18, 2026
dan50
D
Engine Coolant and Radio Issues
  • Don7Up
  • Sep 14, 2025
Fox 5.0 Mustang Tech Oct 4, 2025
Don7Up
D
2001 roush stage 3 - sat for 5 years
  • Brando_05
  • Aug 26, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 26, 2025
Brando_05
