Engine Cuts Out At Upper Rpms
  • Thread starter Thread starter netadmin67
  • Start date Start date Dec 1, 2015
netadmin67
12
Cleveland, Ohio
Dec 1, 2015
  • Dec 1, 2015
Hello all. Noob here. I have a '95 Cobra convertible with original 302, approx. 98000 miles, 5 speed. Car is stock except for MSD distributor, wires, and ignition coil. I'm having trouble with the engine cutting out around 4,000 RPMs and up after the car warms up. I replaced the fuel filter, but that did not seem to help. While the car has been garaged winters and is in excellent condition, I have a feeling that all the sensors are original (20 years old)! Also, I don't feel like the IAC solenoid is right either. I have removed it, cleaned it, and tried to adjust it, but the part is still suspect. In any case, has anyone experienced this behavior before? I have seen a few postings here that seem similar to my experience but not exactly the same. Thanks
stykthyn
5,232
2,652
223
gainesville
Dec 1, 2015
  • Dec 1, 2015
Sounds like the ignition module. I would also say the msd distributor is suspect.
Reactions: A5literMan and jrichker
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Dec 1, 2015
  • Dec 1, 2015
Add another vote for the TFI module and PIP sensor inside the MSD distributor.
The TFI module mounted on the distributor is one of the culprits for a high speed miss on a warm engine. If the problem does not occur when the engine is cold, the TFI module is definitely suspect. You may need a special socket to remove the TFI module, but most auto parts stores will have one for $5-$7.
Be sure to use plenty of the heat sink grease on the new TFI and clean the old grease off the distributor.
See Automotive Tools Specialty | Auto Mechanic & Technician Diagnostic, Testing Equipment | Thexton
diagram courtesy of Tmoss & Stang&2Birds
A5literMan
At least it is lumpy...
5 Year Member
Jul 30, 2011
4,674
2,343
194
Illinois
Dec 2, 2015
  • Dec 2, 2015
X3 on the msd ignition components. You should also check for codes to rule out other issues.
MFE92
1,094
373
124
Phoenix
Dec 2, 2015
  • Dec 2, 2015
MSD usually stands for MySparkDisappeared, but I will say that I chased this kind of thing for an embarassingly long time and what cured it for good was an MSD 5527 Street Fire coil.
netadmin67
12
Cleveland, Ohio
Dec 3, 2015
  • Dec 3, 2015
Thanks for the responses. I appreciate the help. Going to replace the ignition control module and report back.
madspeed
Colonel Mustard
1,332
204
a van down by the river
Dec 3, 2015
  • Dec 3, 2015
The iac will do nothing at those rpm's so rule that out unless you are have idle issues as well, but that's a completey different animal
C
Engine Idle cuts out
  • claypoolxx
  • Mar 7, 2026
Fox 5.0 Mustang Tech Jul 24, 2026
alutwon
Strange timing issue
  • 92 Bimini Blue
  • Sep 26, 2026
Fox 5.0 Mustang Tech Tuesday at 9:33 AM
rednotch
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
