Engine cutting out at various RPMs
  • Thread starter Thread starter tylerrocks
  • Start date Start date Oct 17, 2005
T
tylerrocks
514
Big Spring, TX
Oct 17, 2005
  • Oct 17, 2005
Whats up? I have a stock 260 V8 in my stang. Its got the original carb set to factory settings, Brand new plugs/wires, New Petronix ignition mudule and a fairly new coil. Out of nowhere it just starts cutting out sparaticly. Sometimes it will stop when it's been running for a minute or two, sometimes it wont stop cutting out pieriod. Any diagnosis?
Tyler
LMan
1,246
Mom's basement
Oct 17, 2005
  • Oct 17, 2005
how long has the car been running when this happens?
T
tylerrocks
514
Big Spring, TX
Oct 17, 2005
  • Oct 17, 2005
It starts cutting out right after it cranks up. It dosnt do it while idling I dont have a tach but I would geuss it starts cutting out at about 1500-2000 rpms
Tyler
iskwezm
4,159
20
79
Rowland Heights,California
Oct 17, 2005
  • Oct 17, 2005
Any loose wires,or grounding out???Burn spark plug wires?
2nd Mustang
2,488
Southern California
Oct 17, 2005
  • Oct 17, 2005
Stuck choke? Vacuum leaks? Loose ignition wires? Bad spark plug wires or plugs? I'm sure there are more possible candidates. Good luck.
T
tylerrocks
514
Big Spring, TX
Oct 17, 2005
  • Oct 17, 2005
Everything looks normal. My dad suggested the fuel filter. Think?
Tyler
jerry S
1,365
52.22N 5.12E
Oct 18, 2005
  • Oct 18, 2005
I had a similar problem. I replaced the dizzy, the ignition, the wires, the plugs, and the fuel pump before finally checking the fuel tank, which was full of rust. We drained it and there was enough rust to fill up a cereal bowl. Rust was getting through the fuel filter to the carb and messing with the needles.
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
  • D Durden
  • Oct 20, 2025
  • 2 3
3K
Progress Thread Giving an abandoned 88 GT project a new chance at life
  • jaketractor
  • Jan 9, 2025
2K
Fox 5.0 Mustang Tech Jul 20, 2025
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
2K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
E
Finished my Fox Hydroboost Install - Tips
  • Engineer Duane
  • Apr 9, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 5, 2025
Engineer Duane
E
