  • SN95 4.6L Mustang Tech
Engine died going down the highway, why?
  • Thread starter Thread starter BurningRubber
  • Start date Start date Jul 5, 2006
BurningRubber
1,865
24
58
Jul 5, 2006
  • Jul 5, 2006
I started to slow down for a light from say, 55mph or so... pushed the clutch in and put it in nuteral. I had my foot on the brake and noticed the pedal push back real quick, then it required more force before the brakes would grab. Started to scare the crap out of me, but then I looked at the guages and noticed all the lights came on, and that the tach was dead. So I cranked it over and it started right back up... but the radio or anything didnt die when the engine shut off, kinda wierd.
IAC issues since the engine was returning to idle from when I put it in nuteral?
L
lex8109
  • Jul 5, 2006
Have the same exact issue, but went away lately. It's not the IAC, i had mine replaced, and it doesnt die in the city, only when slowing down from a fast speed in neutral...
04gth
17
Southern California
Jul 5, 2006
  • Jul 5, 2006
hmmm same has happened to me, only when slowin down fast in neutral........
T
Torinalth
952
Clayton NC
Jul 5, 2006
  • Jul 5, 2006
AC on? i know this used to happen to me till i changed my driving habits... RPMS come down, and come down even lower then normal when the AC is on and it just bogs some times. though mine as of recient is due to a missfire... pulling plugs tonight/tomorrow morning to hopefully fix it.
you can always adjust your idle RPM to help prevent this. i have mine at around 900 now as i got sick of it bogging with the AC on.
Torinalth
ADRENLN
2,342
NJ
Jul 6, 2006
  • Jul 6, 2006
that also happend to my car back when i bought it in 02. only a couple of times. same thing i was slowing down for a light and making a turn and everything seemed to locl up. i simply just pushed the clutch back in and started her back up. took it to the dealer.
they installed what they called " new updates" car never did it again.
BurningRubber
1,865
24
58
Jul 6, 2006
  • Jul 6, 2006
A/C wasnt on either. Its done it at low speeds before, usually pulling up to a light or stop sign. The RPM's will dance around from low to around 1100 or so untill it just dies, then itll start right back up. Only happened a few times like that though.
ADRENLN, too bad they didnt tell you what their "updates" were at the dealer. That way I could just go buy the parts... no way in hell id go to a stealership now though, haha.
four six
506
Hobart, IN
Jul 6, 2006
  • Jul 6, 2006
when you guys pushed in the clutch did the rpms drop really fast? then car died?
G
gotchopsticks
315
  • Jul 6, 2006
that happened to me as well, but i was slowing down from about 35, and i started to turn then it died. scared the crap outta me cuz there was another car comming and i couldnt get all the way in my lane. i fabricated that IAC restrictor plate that is often talked about here and it hasnt done it since. but the plate makes me idle lower, and drops RPM's WAY faster. though sometimes when it is really cold it dies....
stanggt00
371
baltimore md
Jul 8, 2006
  • Jul 8, 2006
fck man this is a problem for me the car has done the same thing to me 4 times this month
2times last night when i was comming to a stop at a red ligth dam thing died on me and i almost drifted into the intersection
once when i was slowing down to make a left turn and then again when i was going about 30mph and i pushed the clutch in to drift in neutral going to work it died on me and i almost rearended the car in front of me
so i am training my self to down shift instead of neutral drifting to a stop
laxdman20
95
Va.
Jul 8, 2006
#10
  • Jul 8, 2006
  • #10
If its from highway speeds... EGR? Mine started going dead when you were cruising at 2500 and pushed in the clutch. But it was something in my tune. They bumped up the idle and it hasnt done it since.
karuso99GT
136
St. Louis, Mo
Jul 8, 2006
#11
  • Jul 8, 2006
  • #11
i haven't had that problem since cleaning the IAC.
start there.
BurningRubber
1,865
24
58
Jul 8, 2006
#12
  • Jul 8, 2006
  • #12
Seems like quite a few people have this nagging little issue.
QuickCapri83
80
North East, PA
Jul 8, 2006
#13
  • Jul 8, 2006
  • #13
Has never happened to me with my 99 Limited @ 109k, but, however, i dont use nuetral when coming to a stop from high speed, I leave it in high gear, when i get down to maybe 30 or so I hit 4th, and then, go to nuetral, but I always use 5th down to 4th, all the way down to slow speed, (that is, if slowing from highway speed), pretty much at idle in 4th gear i press the clutch. However, when I like to speed, like, try to top out the car (In very safe conditions and very rarely) when I hit the speed I want, I dont like my rpm's being at 6k and revvin down slow, so i just press the clutch, ac or not, rpm's stay at 1000 no lower, until i get to low speed, then they set at normal rpm.
Basically I like to have torque on my rear wheels, even negative torque, when decellerating and especially into turns...I dunno, rear end of stangs just feels loose if you're in nuetral decellerating through a turn without being in gear, 4th gear atleast, 5th does nothing to help pull the car nice through the turn....maybe it's just me, maybe i'm over analyzing it. Pretty much, I like to be in gear at all times. lol, way off topic, just kinda found it's way into my head and onto here. Sry for long post.
:SNSign:
BurningRubber
1,865
24
58
Jul 9, 2006
#14
  • Jul 9, 2006
  • #14
Little update... clean the entire TB and plenum today, along with the IAC. Car idles alot better, response is alot better, and it feels noticably smoother. No dips in idle or erratic bouncing of the tach yet. Should have seen the ***** that spewed out of the IAC...
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Jul 9, 2006
#15
  • Jul 9, 2006
  • #15
Burning Rubber, can you provide more detail on how you cleaned the TB and plenum? Did you remove them completely from the car to do this???
BurningRubber
1,865
24
58
Jul 9, 2006
#16
  • Jul 9, 2006
  • #16
Yeah... ill do a mini-writeup...
First off, get out the ratchet and assorted socket set and a flathead screwdriver. Those are really the only two tools needed. Buy a can of TB SAFE throttlebody/carb cleaner, it has to be TB safe for the sensors though.
Unscrew the air intake from the throttle body. I unplugged the air temp sensor and just layed it out of the way (I have a FIPK though). So either set aside, or remove intake.
Next up release the throttle cable, and return spring from the TB. Unbolt the bracket that mounts the throttle cable to the plenum, set aside. You should also totally unhook the return spring and set it aside.
Remove vaccum lines from plenum/tb. Remove the IAC line, the line in the back of the plenum, and the red line right next to the TPS. Make sure you remember where they go, or mark them down.
Unbolt the EGR (will take some force, be careful not to strike the plastic intake manifold with the socket... im sure enough force would break that peice of glass... ).
Now take off the 5 bolts holding the plenum on. Remove the plenum with the TB still attached. Once the plenum is removed, be very careful with the intake manifold gaping open... I would highly suggest laying a CLEAN rag across the opening of the intake manifold. Make sure its not dirty, and make sure nothing falls in.
Now that the TB and plenum are off, go ahead and pull the IAC off the plenum and set it aside. Seperate the throttle body from the plenum after that. All 4 gaskets (plenum to intake manifold, EGR, IAC, and TB) are reusable as long as you dont rip them.
After they are all seperated start cleaning them. Spray the IAC several times with the TB cleaner through both openings and watch brown liquid wash out. I wouldnt reccomend poking or prodding any of the openings on the IAC, just spray it out well.
To clean the TB, spray down the butterfly and wipe both sides. The rear part of the TB after the butterfly will probaly be the most dirty part. Wipe it out with the TB cleaner.
When your done with the TB start on the plenum. Mine was a solid crap brown color on the inside... just start spraying and wiping really hard with a rag untill it starts to look like metal again... Take your time and spray out all of the tubing that runs off of the plenum, make sure none are clogged.
Once all the parts are cleaned let them dry of TB cleaner, and re assemble the TB to the plenum, and the IAC to the plenum. Make sure the gaskets match where you mount them up, especially the IAC.
Once its back together, remove rag from the top of the manifold, make sure nothing drops in and reinstall the tb and plenum. Re-hook all the vaccum lines, temp sensor if unhooked, EGR, TPS and IAC sensors, throttle cable, return spring, and mounting bracket... reconnect the air intake and fire her up.
My car idled rough for a short time, even had a noticable miss in the exhaust note. If you want you can disconnect the battery before you pull and clean the plenum. This way it re-learns the idle and whatnot. Only reason I didnt is cause I didnt want to lose my sterio settings...
bluextc
99
South Jersey
Jul 9, 2006
#17
  • Jul 9, 2006
  • #17
This happened to me twice a couple months ago, too (and the second time I was turning into my development and almost hit a school bus! Managed to re-start in time to continue the turn, though). We disconnected the battery for a few minutes, and it hasn't happened since, though I have no clue as to whether that was what solved it or not. It was right after I got the CAI, so we thought it might have had to do with that.
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
  • Gulftown980x
  • Jul 29, 2026
squeak93
Hard to start when engine is cold
  • 86_Capri
  • Mar 11, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
