engine disassembly
  • Thread starter Thread starter shelbe67
  • Start date Start date Jan 13, 2008
shelbe67
309
Jan 13, 2008
  • Jan 13, 2008
I have an engine that I am about to disassemble. It has 30,000 original miles. I thought that it mite have a knock but now I realize that it mite have been a misadjuted rocker. I was looking for an excuse to put my 347 in the car anyway lol. Well I am down to just the shortblock and am gonna strip it down further to freshen up the engine. What should i be looking for? what parts should I keep? the cylinder walls have no scoring so I dont think it has to be bored out. I would like to keep everything as original as possible, this isnt actually for a classic stang the 347 is. This is the original engine to my 93 cobra that I wanna make factory stock again thanks alot guys!
D
D.Hearne
11,730
south louisiana
Jan 13, 2008
  • Jan 13, 2008
With only 30,000 miles, I'd just clean it and put it back together. Leave the short block together, as is, just clean it up. Maybe only install a heavy duty oil pump drive is all.
P
pazur
82
northern Virginia
Jan 13, 2008
  • Jan 13, 2008
rocker can be accessed by removing valve cover only so you don't really have to go very deep. how did you figure out that the rocker is a problem? bad compression?
shelbe67
309
Jan 13, 2008
  • Jan 13, 2008
to be honest the car had tfs heads on it I had never adjusted adjustable rockers before and when I swapped in the other engine I misadjusted them also kinda made the same noise. I have some rust on the cylinder walls forming I just checked the block. I just dont wanna put it all back together in the car and it really be a knock from the bottom end. I have rebiult engines before just never tore one down to make sure everything is ok I always had the intention of rebuilding the engine so I never really cared. thanks!
D
D.Hearne
11,730
south louisiana
Jan 13, 2008
  • Jan 13, 2008
If it's a rod bearing knock, chances are it's a spun bearing. Easy to spot just by removing the rod caps.
shelbe67
309
Jan 14, 2008
  • Jan 14, 2008
thanks guys I am gonna try to get to it tommorrow. what if I have a piston slap? just wondering cause a buddy of mine had that once. If the bearings are ok then it should be ok to just put it all back together? do you think I should do the rings or the bearings while I am there or should it be ok? what should I do about the flash rust on the walls?
D
D.Hearne
11,730
south louisiana
Jan 14, 2008
  • Jan 14, 2008
If it's just surface rust, leave it alone, the rings will take care of it when you fire it up. 30,000 miles, the bearings are just broken in. I'd just inspect it and put it back together if nothing's out of the ordinary.
T
truck90278
382
Redondo Beach, CA
Jan 16, 2008
  • Jan 16, 2008
If you put new rings in , you will have to hone the cvylinder walls (lightly), which will remove any rust.
M
  • Poll Poll
Stroking a Mexico 289 or newer roller 302
  • MaryJaneTheMustang
  • Aug 12, 2026
1965 - 1973 Classic Mustangs -General/Talk- Aug 12, 2026
Bullitt347
1965 Mustang with 80s 5.0 engine in it Power Steering hose or connection ID?
  • spearce
  • May 19, 2026
Classic Mustang Specific Tech Jun 8, 2026
AeroCoupe
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
T
New Guy from Southeast Missouri
  • tcooke11
  • Jan 10, 2026
  • The Welcome Wagon
The Welcome Wagon Jan 17, 2026
TomcatPC
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
