Engine doesnt turn over???
FordRacing302
5 Year Member
Oct 1, 2005
384
42
59
Cleveland, TN
I bought my '83 as a non-running car, and it actually still does not run...It has gas but no spark, but it turned over just fine when I first bought it...I removed the distributor to replace it but never got a chance to get a new one so I dropped the original one back in...After I got it in I hooked up the coil(which was not hooked up when I bought it) but I didnt know what I was doing and jumped the red/light green wire to the positive stud on the starter solenoid and heard something spark when I reconnected the battery...So when I tried to turn it over it wont do anything, it wont make any kind of sound whatsoever...So today I replaced and Starter Solenoid and still nothing and after that I removed the starter and got it tested, and its still good....So I need your guys opinion on what you think the problem is, Im really stumped on what to do...
you need to get in there with a voltmeter/light bulb tester and test out the circuit. verify you're getting juice to the starter relay, then verify you're getting juice at the starter. voltage at the starter, no crank, bad starter. No voltage, you've got other issues. You could have burnt a fuseable link.
Here's a checklist:
Since some of the tests will bypass the safety interlocks, make sure that the car is in neutral and the parking brake is set. Becoming a pancake isn’t part of the repair process…
Check battery, terminal connections, ground, starter relay switch (also known as solenoid) and starter in that order.
A voltmeter is handy if you are familiar with how to use it to find bad connections. Measure the voltage drop across a connection: more than .5 volts across a connection indicates a problem.
See http://www.fluke.com/application_notes/automotive/circuit.asp?AGID=1&SID=103 for help
1.) Will the car start if it is jumped? Then clean battery terminals and check battery.
2.) Check the battery to engine block ground, and the ground behind the engine to the firewall.
3.) Jump the big terminals on the starter relay next to the battery with a screwdriver - watch out for the sparks! If the engine cranks, the starter and power wiring is good. The starter relay is also known as a starter solenoid.
4.) Then pull the small push on connector (red wire) off the starter relay (Looks like it is stuck on a screw). Then jump between the screw and the terminal that is connected to the battery. If it starts, the relay is good and your problem is in the rest of the circuit.
5.) Remember to check the ignition switch, neutral safety switch on auto trans and the clutch safety switch on manual trans cars. If they are good, then you have wiring problems. See http://www.autozone.com/images/cds/gif/large/0900823d80195963.gif for 88-90 year cars .OR see http://www.autozone.com/images/cds/gif/large/0900823d80195964.gif for 91-93 year cars. See http://www.autozone.com/servlet/UiB..._us/0900823d/80/1d/db/3c/0900823d801ddb3c.jsp for 94-95 model cars.
6.) The starter may be hung, loosen up the bolts that hold it on, and give it a good whack with a big hammer. Tighten up the bolts and try again.
7.) If that doesn't work, use a jumper cable from the positive lead on the battery direct to the starter post where the big wire from the relay connects. If it cranks then, it is the power wire from the relay gone bad. This will be hard to do, since there isn't much room to do it.
8.) Pull the starter and take it to Autozone or Pep Boys and have them test it. Starter fails test, then replace it. If you got this far, the starter is probably bad.
