  • 2005 - 2009 Specific Tech
Engine Failsafe mode
  • Thread starter Thread starter superstang05
  • Start date Start date Mar 16, 2008
superstang05
  • Mar 16, 2008
I drove around for about 2 hours yesterday morning with no problems, backed the stang into the garage and 3 hours later when I was going out for another spin the car would start but the engine failsafe mode light was on and the gas peddal was disabled. It ran really rough. I read the manual and it indicated low coolant. Sure enought the coolant was low so I topped it off. I reset the error through the system/reset buttons. When I did another system check it still failed and inticated it was in engine failsafe mode. I called the dealership and was told it is probably the throttle body and to have it towed in. THIS SUCKS!!! Has anyone else had a similar experience? I found a couple postings indicating throttle body problems. Also, does anyone know if there are any more TSB's other than the strut tower bushing and the gas neck? If I am going to take it in I want all of the fixed at once.
Matt
DarkFireGT
Playing with my wife's really makes me want one.
692
10
89
East Moline, IL
Mar 16, 2008
  • Mar 16, 2008
Did you try cleaning your throttle body? That usually fixes that sort of thing. They tend to grab on to oil from your filter (if you're using a K&N style filter) and other things and can really get gunked up.
R
ranger04
245
  • Mar 16, 2008
They sure do, thats why I started using the AEM dryflow cone filters. They make them to fit any intake, they flow aesome, filter great and they don't need oil.
05xgt
78
spring tx
Mar 16, 2008
  • Mar 16, 2008
I had similar problem, but mine turned out to be the accelerator pedal. I don't know where you are located but in Houston there is a tec at Mak Haik Ford named Frank. The guy is AWESOME. He is on top of his game.
superstang05
  • Mar 17, 2008
My Warranty rocks
Good thing I have the extended warranty. The dealer just called and said it was the throttle body that failed. I will find out what they do to fix it and repost later. Also, the TSB for the fuel tank requires them to replace the entire tank.(holy crap) They are going to fix the strut tower TSB as well, and the guy mentioned there is a recall on the passenger side airbag for that year.
Ok, talked to the dealership and they are replacing the Throttle body, heads up guys in case you run into the same problem.
L
2005 gt mustang overheating sensor/failsafe mode
  • lyndenbouw
  • Mar 30, 2025
2005 - 2014 S-197 Mustang -General/Talk- Apr 12, 2025
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
M
warmed up, hard re-starting on hot days
  • michaelleewebb
  • Mar 26, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Mar 29, 2026
michaelleewebb
M
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
