  • SN95 4.6L Mustang Tech
engine fire help
  • Thread starter Thread starter geoff_is_cool
  • Start date Start date Jun 9, 2005
G
geoff_is_cool
24
  • Jun 9, 2005
a few months back i had a new engine installed in my 01gt. it's a jasper rebuilt engine. on tuesday i was driving and i noticed some smoke from the hood. i pulled over and checked it out, the radiator fluid was leaking. i bought some new fluid but the engine was too hot to open the cap and fill it. the fluid was still above the fill line and i was like 2 miles from my friends so i figured id go over there and let it cool down. as i was pulling into his apartmant complex, i saw a lot of smoke so i checked it out, my engine was on fire. i took it to the dealership that installed the engine (i didn't tell them that i knew it was leaking), and they said that the radiator fluid being empty would not have caused the fire but rather that it was caused by the wire going from the battery to my sub box. does it make sense that that would have caused it, or is it the radiator? it also was very hot out that day, like 80-90 degrees outside.
9646gt
595
Holloman AFB,NM
Jun 9, 2005
  • Jun 9, 2005
I have seen quite a few fires in the engine compartment from stereos that were installed wrong..best way to tell if that was the cause is to follow your hot and ground wires from the amp and make sure they arent fried..if they arent I think the dealer is ing you
01SN8K
135
  • Jun 10, 2005
well you need to check the stereo cable like was said. check the insulation to see if it is damaged. one wire cannot start a fire. unless it is exposed to bare metal of the opposite charge. so the positive lead for the amp had to contact something grounded to the car. i highly doubt it was the radiator. one question, before the fire were you happy with the motor, i am asking because i work at a shop that uses their motors.
TL1000S
69
South Florida
Jun 10, 2005
  • Jun 10, 2005
One question, did you fuse it at the battery connection? If you did, then the fust would have blown before the fire starting.
L
Car has been overheating. Not sure what is causing it. Any help would be appreciated.
  • Luckysgirl
  • Jun 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 2, 2026
Luckysgirl
L
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
A
Engine 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Monday at 4:43 AM
manicmechanic007
C
99 mustang gt no signal to fire coils
  • Cerana04
  • Oct 4, 2025
SN95 4.6L Mustang Tech Oct 4, 2025
Cerana04
C
J
High idle 2003 Mach 1
  • JohnnyUtah
  • Mar 29, 2026
SN95 4.6L Mustang Tech Mar 31, 2026
JohnnyUtah
J
