Says I can have for FREE the pistons are 60 over so would need to buy a set....
Going to look for pricing on 2 rods and a piston set. Balancer and flywheel.
My thoughts exactly.... hoping the block I find can be done std or maybe as small as 10 or 20 over.for free is always nice
not a fan of 60 over on these blocks....they are thin wall and that often leads to overheating
The old man says he has a scat9000 crank for a 347 and 6 eagle h beam rods 289 length.. 5.115
I was gonna provide this link the last time you said that......Not the case.....It's a lot of money, but comes complete with the ECU, harness, and trans. it's in the US. ( Well,...It's at least in North America)I am bouncing ideas around now.... I really want that I6 4.0 but unobtanium since you have to ship it into the US in pieces....
I talked to him today after doing some looking, he corrected to say 5.4 or 5.3xx rod length..Is that rod length usable with a typical 347 piston?
Joe
Yeah a bit out of my price range at the moment.I was gonna provide this link the last time you said that......Not the case.....It's a lot of money, but comes complete with the ECU, harness, and trans. it's in the US. ( Well,...It's at least in North America)
This is the top of the line version of this engine,...A turbo Barra, made like 360 hp in factory trim.
https://www.ebay.com/itm/Ford-4-0L-...e-crossflow-motor-Falcon-Aussie-/192314921005
but nnoooo, he waited till you were already back home
Pistons for a 5.3xx rod are crazy expensive for my budget. After balance and flywheel balancer I'll be in it what you can get a balanced assembly new for.
Don't know yet still searching.
Now for the fun part...... HELP ME SPEND MY MONEY!!!!!!!
recommendations for a bulletproof 306
i need to pick pistons, bearings [thinking kings hp series], ring package, head gaskets
can i reuse my ARP head bolts or should i buy studs???
Main girdle??
remember this is a street car will see 10-12psi and watermeth.
Thanks for the input!
Main girdle??
As much as i agree mike, my current budget will not allow for that.... even if i have to put a larger pulley on the blower so it will make less boost = less power..Here's my single, easily proven, told ya so, suggestion to "help you spend your money".
Do not invest a single dime in a stock block that you intend to exceed it's structural limitations in your design stage. As many used World/A-4/Dart/FMS/Boss blocks as there are out there, there has got to be one of them sitting around bare just waiting on you to come up with a thousand dollars to snatch it up
nobody wants to spend my money huh.......
