  • SN95 4.6L Mustang Tech
Engine Engine keeps flooding out
  • Thread starter Thread starter rockyracoon
  • Start date Start date Feb 11, 2023
R
rockyracoon
874
27
49
margate NJ
Feb 11, 2023
  • Feb 11, 2023
I'm thinking maybe my return fuel line is plugged. Can someone tell me which one is the return line at the rail, is it the smaller diameter line I'd like the blow compressed air and see if it goes through
manicmechanic007
5 Year Member
Sep 26, 2017
2,562
727
143
Roy, Utah
Apr 18, 2023
  • Apr 18, 2023
Yes, the smaller line is the return
Simply check the fuel pressure and regulator operation to see if it is plugged
We used to have to block off the fuel return line to use the Rotunda (Ford) injector cleaner equipment
When you do that, the regulator vacuum on or off will have no effect
Never seen one plug up. Why are you thinking yours is plugged? Pig Fat Rich?
Better check the codes
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
Engine Motor swap from a 2003 Explorer
  • 1996mustang new
  • Oct 9, 2025
SN95 4.6L Mustang Tech Oct 16, 2025
squeak93
  • Gulftown980x
  • Jul 29, 2026
squeak93
L
1997 V6 Starting issue
  • leanzik04
  • Mar 20, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Mar 20, 2026
E
Chasing Vacuum leak 99 GT
  • EBNS_2005
  • May 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 3, 2026
X-cam34
