Engine Knock....
  • Thread starter Thread starter MahFiVeOh
  • Start date Start date Aug 3, 2005
MahFiVeOh
531
9
49
Ontario, Canada
Aug 3, 2005
  • Aug 3, 2005
I just noticed i have a engine knock from the bottom end, a buddy says its probabaly a crank bearing .Is this fixable without pulling the engine? or am i screwed
RsStanG1987
I shaved all my pubes playing this game.
569
9
79
Dupont PA
Aug 3, 2005
  • Aug 3, 2005
Your pulling the engine. Your gonna need to lift the engine to get the oilpan off so you mindswell pull that sob out and get it rebuilt. Im sure your crank may need to be grinded now too.
MahFiVeOh
531
9
49
Ontario, Canada
Aug 3, 2005
  • Aug 3, 2005
uh oh I was afraid of this.
Black 93 Fox
1,995
Vancouver,Washington
Aug 3, 2005
  • Aug 3, 2005
Yeah I had some what the same problem as you last year. I just took it out and rebuilt the motor while it was out. Might as well do it right the frist time instead of having to do it twice.
89CopCoupe
Banned
Feb 17, 2004
606
Post Count City
Aug 3, 2005
  • Aug 3, 2005
Who the hell said 331 stroker kit
bsedwebt70-5.0
320
Charlottesville, VA
Aug 4, 2005
  • Aug 4, 2005
Had mine done a few months ago - did not pull the engine - dropped the pan - replaced rod and crank bearings, oil pump, etc... crank was good - caught it before it went too far - all you can do is try - see what it looks like - all depends on what you want to do.
txstang84
1,639
42
69
Tuscola, tx
Aug 4, 2005
  • Aug 4, 2005
yeah, i've done that one before too, but it's only a band-aid fix, if your bearings are carved up, more than likely so are the bearing journals, then just putting in new bearings will only delay the real problem...
at least pull it and freshen it up, whoever mentioned getting your crank ground or even throwing in a new engine-they're both right!
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
C
Boosted Boss 302 HP/TQ
  • coltoncaskey12
  • May 24, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech May 24, 2026
coltoncaskey12
C
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
Engine Obstinate Pilot Bearing removal
  • FastDriver
  • Feb 12, 2026
  • 2 3
Fox 5.0 Mustang Tech Feb 22, 2026
manicmechanic007
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
MadSquirrelTech
