  • SN95 4.6L Mustang Tech
engine knockin noise?
  • Thread starter Thread starter mattch2
  • Start date Start date Aug 21, 2006
M
mattch2
505
Niagara Falls
Aug 21, 2006
  • Aug 21, 2006
okay guys the other day I had my car out and i decided to get on it while in 2nd gear... i brought it up to redline then shifted into 3rd but it never shifted....my rpm's just kept banging of rewdline for a steady 5 secs or so ..I didnt realize right away but my facking floor mat had pressed the gas peddle down all the way to the floor.... so once i realized it i took it out and stopped the car..when i put it back into 1st gear and started to let the clutch out i heard a knocking noise coming from the engine... now it does it in neutral,1st gear and 2nd gear..but it quietns down in 3rd and forth but you can still hear it.. I cant determine if its coming from the bottom end or the top end of the motor.... Do you guys know what extent of damage this has possibly done?.. Someone told me it may be a floating valve, and i may need a valve job done?.. I know it can be somethign else but what do you think id be looking at $$$$ wise is this scenario.. Id like to have a good knowledgble idea before i have it at the shop this week!!!!
Appreciate it guys!!
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Aug 22, 2006
  • Aug 22, 2006
Sounds real bad man
Let us know what the shop says...
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Aug 22, 2006
  • Aug 22, 2006
you spun a bearing.. time for a new motor
d98gt
4,505
59
204
SE Texas
Aug 22, 2006
  • Aug 22, 2006
Ouch, bad news if its a spun bearing.
Best of luck man.
Pughman
295
in a galaxy far far away"MISSOURI"
Aug 22, 2006
  • Aug 22, 2006
good news ! you get a new motor !
M
mattch2
505
Niagara Falls
Aug 22, 2006
  • Aug 22, 2006
well lets go based on IF i have spun a bearing and its time for a new motor...where do i go from there.. im not knowledgeable on all that internal stuff but what would i need?..Do I use the same block but just change rods pistons.etc....?? or do i need a new block all together? also what would i look at when deciding which blocks to go with etc?..Now im thinking future plans to have a 2.2kb so this may not be a bad idea but didnt expect it to all happen so sooon.
Mike97gt
it doe snot
10,633
Aug 22, 2006
  • Aug 22, 2006
depends on what bearing spun.. plus it depends on how much damage you did to it running afterwards with a spun bearing..
Built98GT
211
OKC
Aug 22, 2006
  • Aug 22, 2006
Exactly 1 year ago I spun a bearing, and now I have all the mods in my sig.lol I would say buy a built shortblock from MPH or DSS or some other company like that. Make sure you get it built for low compression since your wanting to put a KB on it. I went the way of building my own block in my car. We bored mine 20over and used eagle h beam rods and Probe 17cc pistons. I think just buying a built block would be the better way to go however.
96_SVT_VeNoM
Banned
Jul 17, 2006
Fontana, Ca
Aug 22, 2006
  • Aug 22, 2006
Sounds like someone else i know *Cough* 01Steeda.
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
Drivetrain Downshifting from 3rd to 2nd issue
  • Scott_S
  • Apr 23, 2026
Fox 5.0 Mustang Tech Oct 12, 2026
limp
J
Reduced power in 1st and 2nd gear
  • jimted79
  • Feb 25, 2025
SN95 4.6L Mustang Tech Feb 25, 2025
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
