  • 2010 - 2014 Specific Tech
Engine Light Flashing Question
  • Thread starter Thread starter jbrillo
  • Start date Start date Sep 27, 2012
jbrillo
229
Houston
Sep 27, 2012
  • Sep 27, 2012
This does not happen all the time, nor does it occur frequently. When it does happen, I can't help but wonder if there is actually something wrong. Sometimes, under hard acceleration, the egnine light will start flashing. I let up on the throttle and a few seconds later, the flashing engine light goes away. There are no odd sounds or anything else associated with this event. It just seems to randomly occur. If anyone else has or had this issue, any help would be appreciated. Thanks!
wicked400ex
17
  • Sep 27, 2012
Yes, there is something possibly wrong. If you don't have anything that may void your warranty, make an appt. with the dealer and let them find out why it's happening. Could be as simple as a software update..
bigb427
128
Las Vegas, NV
Sep 27, 2012
  • Sep 27, 2012
The one and only thing that will make the check engine lamp flash is a bad engine missfire. All other emissions or electronic engine control faults will cause the light to come on and glow constantly. A miss that's less severe won't even make the check engine lamp flash. Are you certain it's the check engine lamp?
stang8urimport
Autozone Junkie
1,499
12
59
Daytona Beach, FL
Sep 27, 2012
  • Sep 27, 2012
CEL will only flash if the misfire is bad enough to do damage to the catalyist. Get it looked at ASAP.
jbrillo
229
Houston
Sep 27, 2012
  • Sep 27, 2012
Thank you guys! I actually just read in the manual that flashing indicates a misfire. The car is stock, so no problems with warranty. I will take it in tomorrow. Hopefully it's nothing big.
jbrillo
229
Houston
Oct 11, 2012
  • Oct 11, 2012
Finally got my car back after a week! It took so long because they also had to replace my drivers side seat cover as the leather was starting to tear. They found the #2 coil & spark plug to be at fault. Both were replaced and I'm happy to report that the car feels great again.
P
2000 GT Random Power Loss
  • Pinellas50
  • Mar 9, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 23, 2026
Pinellas50
P
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
More Issues With New Edge
  • Blackout67
  • May 3, 2025
1996 - 2004 SN95 Mustang -General/Talk- May 11, 2025
Blackout67
Hard to start when engine is cold
  • 86_Capri
  • Mar 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
  • Gulftown980x
  • Jul 29, 2026
squeak93
