It ran fine before it happened, then out of no where it starts acting like this.
I changed the fuel filter, changed a plug wire that got too close to a header (thought that was the problem), changed that plug, check maf voltage and it's there, same goes for tps. Cleaned the IAB, looked over the entire engine for anything wrong, nothing.
It idles perfectly, it drives ok until you get into the upper rpm band, and most noticeable at WOT, where the engine seems to lose all power, like it bogs down, and revs slowly, it's not cats.
I can't think of anything else that would cause it. Any suggestions?
I second checking the TPS for a dead spot. I believe it should have 5.v at WOT.
