Do you guys know what the 4 bolts that run through the engine mounts, into the block look like? I didn't label my bolts very well, but one of them is still attached to a wire harness, it is more like a stud with a nut half way down, then a clamp that holds the wireharness, then a nut on that. Do all 4 look like this, (I have 3 others in the box) or should i be looking for actual bolts?
thanks
thanks
