  • 1994 - 1995 Specific Tech
Engine Mount Help!
  • Thread starter Thread starter 69clark
  • Start date Start date Dec 1, 2005
69clark
731
Ravena, NY
Dec 1, 2005
  • Dec 1, 2005
I am about ready to pull my engine and wanted to know what the best way to unbolt the engine mount. Should I unbolt it from the motor or unbolt it from the chassis. I ask because looking at a pic of the mount it looks like the bolts bolt to the chassis at a 45 degree angle and I am not sure if it will catch on the chassis when I pull it with them still bolted to the motor. Thanks Guys!
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Dec 2, 2005
  • Dec 2, 2005
i unbolted from the chasis (k-member) if you jack the car up and get under there you can see the bolts pretty easily, only 1 on each side. soak em eith some lube first and they should come right off
mytight95
2,605
Dothan,Al
Dec 2, 2005
  • Dec 2, 2005
yup, just done the unbolting them thing.....lol
jason
ProKiller
3,064
15
78
PA
Dec 2, 2005
  • Dec 2, 2005
your never going to reach the block bolts while its in the car. there are too many brackets in the way to get on them. unbolt it from the k-member. spray some lube like urban said. might be a bit hard to break it but they turn pretty easy once u do.
VibrantRedGT
"STANGNET'S PENGUIN SMACKER"
424
154
Boca Raton, Florida
Dec 2, 2005
  • Dec 2, 2005
There are only two 15/16th nuts that need to be removed which are located in the motor mount area.
Stangfreak95
add a 4
3,571
In your sister. If none, your mom
Dec 3, 2005
  • Dec 3, 2005
Chassis is way easier
T
Fox *Solved* Motor mount bolt question
  • TDM389
  • Mar 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 22, 2026
TDM389
T
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
A
Catch can questions.
  • AngryH58
  • Sep 26, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 29, 2026
squeak93
P
2002 T5 transmission vibration issue
  • puffoo
  • Feb 22, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Feb 22, 2026
puffoo
P
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
