Engine Mount Removal??
  • Thread starter Thread starter gooch06
  • Start date Start date Apr 25, 2005
G
gooch06
117
  • Apr 25, 2005
What;s the best way to remove the Engine mounts on a 1990 5.0 Mustang? Can't seem to get a wrench on the nuts in the back. Please anyone have any ideas that would be great. Thanks
gregpro50
140
Binghamton NY
Apr 25, 2005
  • Apr 25, 2005
Un-bolt the mount where it meets the K-member and jack up the engine. That will give you the room to turn some wrenches.
HISSIN50
34
129
Apr 25, 2005
  • Apr 25, 2005
and on the pass side, i disconnected the battery and removed the starter cable where it affixes to the starter. with that moved, i could get some extensions and universal (swivel) sockets on the nuts.
good luck.
vristang
4,933
101
124
Seattle
Apr 25, 2005
  • Apr 25, 2005
I use a wobbly (swivel) extension also. I would want to loosen all the bolts before jacking up the motor though. With the motor in the air it will just twist and bounce around when you try and pry on the bolts. Then again I've never done it this way, so what would I know?
Mavrick
2,264
Collingwood, ON
Apr 25, 2005
  • Apr 25, 2005
I got to the two motor bolts under the car, and got to the big motor mount nut from in the wheel well (with the inner fender and wheel removed). I couldn't get my hands on an engine crane, so i used a jack and a block of wood under the oil pan.
This was surprisingly EASY to do!
Good luck.
T
Fox *Solved* Motor mount bolt question
  • TDM389
  • Mar 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 22, 2026
TDM389
T
  • brandyn200
  • Jun 20, 2026
AeroCoupe
D
Paint removal on machined gasket surfaces.
  • Ddyer2868
  • Feb 16, 2026
1965 - 1973 Classic Mustangs -General/Talk- Feb 23, 2026
ctandc
C
1990 foxbody 5.0 fuel system.
  • staceyj
  • Nov 28, 2025
Fox 5.0 Mustang Tech Nov 28, 2025
Mustang5L5
Front brakes not releasing
  • Boats90GT
  • Sep 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 16, 2026
AeroCoupe
