Engine need balancing even with stock internals?
  • Thread starter Thread starter 95_5.0_stang
  • Start date Start date Dec 11, 2006
9
95_5.0_stang
172
Lansing, MI.
Dec 11, 2006
  • Dec 11, 2006
I'm rebuilding a motor and wondering if I need to have the rotating assembly balanced if I'm using stock internals? The cylinders have been honed and checked by a machine shop. He said there is no need to bore .030. The thing is, the crank will be a brand new (not stroker) 302 crank, pistons/rods will be the old ones cleaned up. Rod/main bearings will be STD. I will have it balanced if it's really needed but if not, then I don't see why I should waste the money. Also, I've searched but can't find an exact answer to this. Thanks.
DMAN302
My mom says thanks for the pearl necklace.
Nov 8, 2003
2,120
windsor, Canada
Dec 11, 2006
  • Dec 11, 2006
Since vibration can tear the mill apart I'd say the added expense to balance would be worth it just for peace of mind if nothing else.
dastang2
2,020
tx
Dec 11, 2006
  • Dec 11, 2006
no it's not needed unless you wanted to turn higher rpms
9
95_5.0_stang
172
Lansing, MI.
Dec 11, 2006
  • Dec 11, 2006
Errr...one of you guys going each way. More opinions welcome.... Thanks so far guys!
1Bad88notch
62
Leesburg,FL
Dec 11, 2006
  • Dec 11, 2006
I would get it balanced to be safe since you are rebuilding it.
JChalfan
551
Bellevue, WA
Dec 11, 2006
  • Dec 11, 2006
Personally I'd balance it. Like DMAN said, it's worth the $$$ for peace of mind if nothing else.
It certainly won't hurt.
Jeff
9
95_5.0_stang
172
Lansing, MI.
Dec 11, 2006
  • Dec 11, 2006
Jeff
Yea, I understand what ya mean, but I'm not into spending $150-200 just for peace of mind. Lol. Either it needs it or not...which I wouldn't know until it was done. I'm just looking for people who have done a stock rebuild like this to see what they've done.
ozanracing
172
  • Dec 11, 2006
As long as the piston and and rods are the same weight, and the crank is the same, you don't need to.
FSTRDNU
76
  • Dec 11, 2006
yes, get it done, you actually pick up hp, from balancing
JChalfan
551
Bellevue, WA
Dec 11, 2006
#10
  • Dec 11, 2006
  • #10
I think he said it has a new crank, which is one of the reasons I recommended the balancing.
I agree if you're doing a budget rebuild on a stock motor, keeping the stock crank, rods, and pistons (in the correct locations), you could get away without balancing.
It just seems to me it's something you will probably use for years to come. The cost of balancing doesn't seem that bad in the long run...
95_5.0, is the car going to stay stock, or is it going to be modded at all?
Jeff
Modular2v
3,222
23
99
oklahoma
Dec 11, 2006
#11
  • Dec 11, 2006
  • #11
if it is a 50oz 302 crank and the pistons and rods are from a 50oz motor (should have an e7 number on them) Then i would not balance it as it is not needed
Rick 91GT
Mustang Master
95
99
PA
Dec 12, 2006
#12
  • Dec 12, 2006
  • #12
IT NEEDS TO BE CHECKED AND MY BET RE-BALANCED, due to all the production variances you will need to have the bob weight checked (piston/rod/ring/rod bearing) and the crank spun. You would be surprised how different the bob weights are on some of the stock motors I have pulled apart...
2000xp8
SN Certified Technician
Aug 8, 2003
8,078
1,659
194
NJ
Dec 12, 2006
#13
  • Dec 12, 2006
  • #13
You're not into spending $150-$200 for peace of mind?
It will cost you that much in new gaskets if it's messed up.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Dec 12, 2006
#14
  • Dec 12, 2006
  • #14
I did a stock rebuild (.030 pistons), used stock crank, stock rods...
$150 well spent...
Get it done, the engine will rev smoother (more hp?) and last longer...
With a new crank and reusing the older parts, the mixing and matching tells me to have it balanced...
Good Luck with it!
ninety15.0
1,336
#15
  • Dec 12, 2006
  • #15
I was in a similar position to yours and i decided the money was well worth it. A couple hundred bucks up front is well worth a smooth revving, more powerful engine, along with the 'peace of mind'. I dont spin my motor past 5500 but i like knowing that 6k wouldnt hurt it if i mess up and over-rev. Lots of good advice from competent stangners who are saying the balancing is in needed and worth it. I would heed their advice.
Red88 RICK
101
Connecticut
Dec 12, 2006
#16
  • Dec 12, 2006
  • #16
OK i just got a new STOCK crank from ford racing and im using the old connecting rods but new .030 speedpro pistons. the whole motor is pretty much stock just everything new except for the connecting rods i put the whole bottom end togeather then i remembered to have it balanced should i bother taking it apart just to balance? or with all the stock stuff except for the .030 over will it still be all screwy
Rick 91GT
Mustang Master
95
99
PA
Dec 13, 2006
#17
  • Dec 13, 2006
  • #17
With the addition of the .030" pistons it will need to be balanced, any change it rotational weight will throw it off.
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
My next project , a 428 build!
  • horse sence
  • Jul 29, 2026
  • 9 10 11
5K
Classic Mustang Specific Tech Thursday at 6:45 AM
DadLife0724
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
H
1966 mustang starter and pulley troubles
  • Hotrods4ray
  • Sep 24, 2025
1965 - 1973 Classic Mustangs -General/Talk- Jan 10, 2026
Realmongo
