I need to find the vacuum reservoir for the smog pump. If you look at the 2 solenoid valves on the passenger side inner fender well metal, there are the 2 Thermactor Air (smog) pump valves that control the flow from the smog pump to the cylinder head or the exhaust system.
Smog pump solenoid airflow control valve (standalone view)
I have vacuum being delivered to a tube in a hole in the fender well and a vacuum line coming out of the fender well in the same spot. But I don't have any vacuum at either one of the 2 control valves.
Has anyone removed the passenger side fender or inner fender liner? I need to get in that area to inspect for damage and loose vacuum lines.
See areas 1,2,3 on the picture below...
