Engine noise diagnosis help request
  • Thread starter Thread starter emutt
  • Start date Start date Apr 11, 2005
E
emutt
Vista, CA
Apr 11, 2005
  • Apr 11, 2005
Hello All,
On Friday my car started making a noise that I'm trying to track dow and hopefully fix without too much $$. There is a front end ticking/knocking that only appears or is noticable under load and when accelerating. At idle or while cruising or very gradually accelerating it's not noticable, but push the gas a little harder and the knocking starts up and changes with engine speed. Revving in neutral or clutch disengaged did not cause the noise.
A couple weeks ago I changed cap/rotor/plugs/wires due to wear, but failed to check the timing. Yesterday I checked the timing and adjusted it. It was a little off, but not too bad. Revving engine in the driveway while under the hood, again, did not reproduce the noise.
Subsequent road test showed sound was still there.
Any ideas regarding what would cause this sound under the specific loaded/accelerating conditions?
The car:
65 A-code coupe, 3-sp manual, no power steering or brakes, Edelbrock carb and intake. Hooker headers and dual exhaust, electric fuel pump, centerforce clutch, MSD 6A and pertronix, block and heads are rebuilt replacement for stock and has ~60,000 miles.
Thanks,
Eric
N
nds03
166
  • Apr 11, 2005
retard the timing some more and then see if it still does it
thehueypilot
1,084
Medina,Tennessee
Apr 11, 2005
  • Apr 11, 2005
Could it be spark knock from bad gas if it comes a goes with power application? Try taking out a bank loan and putting 93 octane in it to see if it goes away.
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
R
03 Mach 1 (tremec 5 speed) - Clutch/transmission noise help
  • rvrstxyz
  • Jan 21, 2023
3K
1996 - 2004 SN95 Mustang -General/Talk- Jan 23, 2023
weendoggy
Engine ticking noise
  • 01 zinc cobra
  • Jan 11, 2022
1996 - 2004 SN95 Mustang -General/Talk- Jan 16, 2022
Neuron
