  • SN95 4.6L Mustang Tech
Engine Noise
  • Thread starter Thread starter bullitt_2620
  • Start date Start date Aug 7, 2006
bullitt_2620
91
San Diego, cali.
Aug 7, 2006
  • Aug 7, 2006
In the past day or so, i've noticed a very odd sound coming from my engine bay when I give it gas, more noticably at at least 1/2 throttle. I'm pretty stumped at what it could be, but it doesn't sound very good. The best way I can describe it is that I can hear the engine working more... It's never been this loud before. Any suggestions??
hotrodnut
672
North Florida
Aug 7, 2006
  • Aug 7, 2006
Cats clogged, needs spark plugs, leaking exhaust, air filter dirty, coil pack going bad, are you down on power or using more gas?
M
my95gtstang
76
Chesapeake, VA
Aug 7, 2006
  • Aug 7, 2006
i've had this problem recently. i changed the spark plugs and it stopped it from bogging down. i have other problems that also need fixing but my advice is check spark plugs.
bullitt_2620
91
San Diego, cali.
Aug 7, 2006
  • Aug 7, 2006
I have no cats, I highly doubt it's an exhaust leak, filter is clean, and I don't know when the spark plugs were replaced last. I've had the car almost a year, and I know its sounds pretty well, and this just doesn't seem normal. How would bad spark plugs make it louder inside my car? BTW, the sound is much more apparent in lower gears, usually say, cruising at 2k rpms, then half throttle.
hotrodnut
672
North Florida
Aug 8, 2006
  • Aug 8, 2006
What mufflers are you running? Maybe they are burning out some and causing the extra noise?? When you get up to speed then, in a sense, you may be out running the louder noise so it's not as noticable in the upper gears.
I know my Son's and my Mustang are louder at 2k than probably anywhere in the RPM range.
Bad/weak plugs could cause a slight misfire that may cause the cylinder cycle to be off slightly and make for a louder/odd tone.
bullitt_2620
91
San Diego, cali.
Aug 8, 2006
  • Aug 8, 2006
I have the stock bullitt catback. I don't think it's the mufflers, the sound sounds like its coming from right on the other side of the firewall in front of the driver's seat... I guess i'll try changing the spark plugs and see what happens. Is there a write up somewhere? Haven't done it on a mustang yet. Thanks for the help.
myponyrocks
I have more billet on the Stang than most women ha
Apr 18, 2004
1,219
Aug 8, 2006
  • Aug 8, 2006
for plugs, just make sure the engine is cold. Do yourself a favor and buy one of those flexible plug wrenches for like 20 bucks. shouldn't take more than 10 minutes.
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
Engine Strange Noise
  • burntokita
  • May 8, 2026
Fox 5.0 Mustang Tech May 11, 2026
keel
  • Gulftown980x
  • Jul 29, 2026
squeak93
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
O
Sooty/Oily Front Engine & Pulleys
  • ozenator
  • Jun 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 22, 2026
Blackhawkxx
