  • 1994 - 1995 Specific Tech
engine noises
  • Thread starter Thread starter sleeperstang199
  • Start date Start date Aug 4, 2007
sleeperstang199
78
harrisburg, Pa
Aug 4, 2007
  • Aug 4, 2007
Recently installed a set of AFR 165cc heads and a steeda #19 cam with a trick flow street intake. when i ran it for the first time it sounded like the engine had a valve tap. so i tore the heads back off but everything was ok. i thought maybe it was a collapsed lifter so i replaced all the lifters and pushrods but the noise is still there. oil pressure is ok and i cant think of anything else that would be wrong......any ideas....????
earleys94gt
1,223
Ashley, Ohio
Aug 4, 2007
  • Aug 4, 2007
With the Steeda cam, being higher lift than stock...maybe could be rocker shims, or improperly adjusted rockers . Are you absolutely sure it's "valve tap" and not "pinging"???
sleeperstang199
78
harrisburg, Pa
Aug 5, 2007
  • Aug 5, 2007
when it gets warmed up it pings a little but the valve tapping is all of the time. how do the rocker arm shims work. i was told that with bolt on rockers you just had to torque them down in sequence. the shims adjust the height right??? how do you check weither you need a shim or not
juiced_94gt
1,143
Southern California
Aug 6, 2007
  • Aug 6, 2007
you have to acheice the torque spec within 3/4 of a tur to 1 1/2 turn, if its less than 3/4 of a turn you need longer pushrods, if it's over 1 1/2 turn then you have to start shiming This is for pedestal mount heads with non-adjustable rockers.
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
Engine Strange Noise
  • burntokita
  • May 8, 2026
Fox 5.0 Mustang Tech May 11, 2026
keel
G
Engine Pushrod Length Question
  • germain101
  • Sep 22, 2025
Fox 5.0 Mustang Tech Sep 25, 2025
Fox Help
  • 93fox85
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 23, 2026
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
