engine prknocking-banging
  • Thread starter Thread starter Scott W
  • Start date Start date Jun 6, 2004
Scott W
1,768
Toronto, Ontario
Jun 6, 2004
  • Jun 6, 2004
engine knocking-banging help please
I was having some drivability problems, mild surging, some lack of power... but it wasn't too bad. today however, after getting off the highway, I satrted to have some real drivability issues - severe surging, and there is a loud banging or clanking noise coming from the engine when i hit the gas pedal. its way louder than any ticking from the valves - any ideas? crate engine time?
sublime29
110
  • Jun 6, 2004
The mild surging and lack of power could be a sensor.Like always the 1st thing you should always do with late model car.You pull out the cheap code scanner.If that checks out it might be internal.Check the timing and for vacuum leaks.Get a mechanics steathascope or a length of tube about size of rad hose. Then start to go all over engine with one side to you ear and probe the engine everywhere with the other side listening for your knock.
BlackFox5.0
3,514
Massachusetts
Jun 6, 2004
  • Jun 6, 2004
Are you sure it's not detonation? Whats your timing set at? What octane gas do you run?
Scott W
1,768
Toronto, Ontario
Jun 6, 2004
  • Jun 6, 2004
No, I gaurantee its not detonation. this noise is pretty loud, the car sounds like a clunker.
I thought it was a sensor, or dirty injectors, ran all the codes, replaceed many sensors, new ignition.............But today, the noise started, and the problem increased 10 fold.
I'm going to drive it into ford tomorrow, and get an engine diagnostics. I thinks the mechanic will have some idea just listening to the engine.
I should include I have almost 300,000 km on the stock engine!
Scott W
1,768
Toronto, Ontario
Jun 7, 2004
  • Jun 7, 2004
well i found the problem. turns out my header gaskets are leaking, in fact 3 bolts have come loose and completely disappeared!
does anyone know if the header leaks could cause mild surging? (feels like your just starting to run out of gas)
Scott W
1,768
Toronto, Ontario
Jun 7, 2004
  • Jun 7, 2004
well ford just called again - one of my new msd wires has melted to the header, causing a misfire.
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
is my car dead
  • kenzo0315
  • Jun 30, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 8, 2025
kenzo0315
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
