Need some help here.
I have a rebuilt stock 351C 4v, except for small cam. It is back firing when accelerating, I have moved the timing around and tried everything there. I had the MSD distributor and removed it, installed the stock dist and it is still doing the same thing. I've changed the stock intake to an aluminum Torker....didn't help. The 70 Mach I has a factory tach that is working correctly, I still unhooked all the wiring and just hot wired it thinking I may have a short somewhere in the tach wiring. It's still missing and back firing.
There is a real strong gas smell and black smoke when it is idling. I had the motor professionally rebuilt, heads worked, everything. The only thing I can think of now is that it may have a broken valve spring. Anyone else have any ideas. It's really discouraging!
