#1- This plug runs along side a vacum line that goes to manifold in the front of engine. It will plug in to a/c but so does the wire in picture #3. So im confused with which one goes where. Where does this go?
I yanked out some b.s alarm that was installed on the car and it looks as though this relay was tapped into the starter solenoid wire. Can I delete this relay, Is it not stock?
Here is the other wire that has the same plug as number one picture. Does this go to the ac? Where does this go? It is on the same harness as and close to the coolant sensor.
Lastly, the wire iam holding is from the starter. Does this go where my fingers are about to put it? and did i put the other wire (ground) on the right terminal? Also, i have a 3 g that iam about to wire. What terminal do i put the 4 gauge wire to? The leeft or right? Thanks
